garage bluetooth speaker (plug-in not battery, <$100))
R-mm
The vast majority of bluetooth speakers I see are either pricey (sonos etc) or designed to be USB charged or used on battery power. Anyone have a simple speaker they like, below a hundred bucks that is designed to replace a regular plug in radio?
Have read threads on using a bluetooth adapter on a 'regular' stereo but I just want something small to replace an old radio that no longer gets any reception.
NUTTSGT
Northern Central Ohio
I bought one of these at Lowes. I used a $50 gift card and military discount so it was cheap in price for me. I've had it for over a month and a half with several hours of play time but haven't used it in the last couple of weeks but it's still got battery juice left.
Sure it's charged via a USB but that's not a big deal. Just plug the cord into an older cell phone wall plug.
https://www.lowes.com/pd/EcoSurvivor-Bluetooth-Speaker-with-Built-In-Battery-Pack/1000578759
DFB
Southern VT/Western Mass
Gawd there a soo many BT speakers on the market everywhere now :bounce:
Can't say how good most of them are. Of course sound quality, volume level and battery life is important. And some really cheap ones cant be used while charging.
But I do have 5 different ones I can tell you about. The Monster is good personal speaker quite loud, but really for indoor use as it not water resistant rated. Has an FM setting.
Altec Lansing H2O is tough weather resistant rubber shelled, not as loud as the Monster.
Small Milwaukee M12 speaker I use outdoors a lot especially hiking or snowshoeing it clips to a pack sound quality varies depending on the type of music or recording quality. With the removable/replaceable batteries it can go all day long.
The bigger Milwaukee BT speaker though doesn't normally fit into the sub $100 category is just awesome though and I really cant say enough good things about I use it extensively well worth the investment IMO. Sales can be found on it though to make it less than $100. It can blow you right out of the garage depending on the recording level of your music too! :D
I also have cool little Sunex Tools Socket speaker looks like a 2" deepwall socket, battery time is minimal and not very loud and if IIRC thinking cant be used while charging but it has a huge magnet and attaches easily to tool cart or box and also does FM.
Sunex did offer a larger speaker last year its was ACME web site but haven't looked for a while
Lucid Moments
Gainesville, Ga
I am with the OP. I don't mind if it has a battery, but I do mind paying for the battery. I am looking a speaker that will not be mobile, will always sit in the same spot. No battery is needed and I would rather spend more for a nicer speaker. I really don't think that such a thing exists though.
DFB
Big Milwaukee BT speaker comes with an AC power cord and does not need the optional batteries to be used.
Just as an FYI the 2891 DOES NOT replace a radio though where others some do have an FM setting (that was also a requirement of the OP'S.)
TriumphFan
North Georgia
B-Well
Eastern VA
Have you considered just adding a Bluetooth receiver to a "home" stereo. or even a powered PA speaker? Come to think of it, there are quite a few PA speakers with Bluetooth built in.
CJ7VFR
Central New Jersey
You can use pretty much any Bluetooth speaker you want, even one that uses a battery. You can just leave it plugged in all the time if you want, even after the battery is fully charged. Just stick it up on the shelf, plug it in, and forget about it. You can't over charge them, and nothing bad will happen to it by leaving it plugged in all the time.
All of these Bluetooth devices, with the USB charging cable, can be hooked up to a 5V plug adapter that most people call a wall wart. This is the generic term for the adapter that you plug the USB cord into, and then plug the wall wort into any 15 or 20 amp regular house receptacle. You do not need to plug Bluetooth speakers into a computer to charge them or power them.
If you have a cell phone, that came with a wall charger adapter, you can even use that if you want. That is the wall wart part I am talking about. They are all 5V.
You can buy the wall warts at any place like Walmart, or Amazon, or even in big box stores like Home Depot or Lowes. And they are cheap too. You can get them for under $5.00.
Another option would be if you already have an old boom box of some sort, that might have an aux jack on it. This will usually be a jack that is 3.5mm, similar to a headphone jack. If you do have an old boom box with this, you can buy a simple Bluetooth receiver for around $20.00 to plug into the aux jack, giving you the ability to stream music to your old boom box!
And most of the Bluetooth receivers get their power from the aux jack, so no other plug or power source is required.
Jim
Citation
Indy
You might consider a pair of BT speakers with a built in amp. You could place them side by side or apart.
https://www.amazon.com/dp/B016P9HJIA/?tag=atomicindus08-20
Personally I would go for the old stereo+BT adapter or old computer speaker 2.1 system + BT adapter
https://www.amazon.com/dp/B00CDJJZV6/?tag=atomicindus08-20
https://www.amazon.com/dp/B0151K2AB0/?tag=atomicindus08-20
My current garage setup is a Logitech 2.1 system sub/amp + some small speakers. I don't have a BT adapter on it right now but I've been tempted to change that. However I don't mind stringing the whole thing up. No doubt a simple BT speaker would be an easier install.
dcs13
The Hill Country ,Texas
I am totally happy with this.. I take it to the shop I work at, bring it home on weekends. I use it at least 6 hours a day. Been great.
Bodj Built
Moorpark, CA
We had a couple of Sony tower speakers from our in home stereo that have been sitting unused for the better part of 15 years. I bought a small bluetooth amp from Amazon that the speakers plug right into. Awesome sound and cost me around $35 or $40. Nothing to charge, and my phone doesn't have to be hooked up to anything. Has good range as well.
Firebrand
New Hampshire
I use a set of Bose computer speakers. These were an eBay score at $55 and run on 12 volts DC but came with a wall adapter. They connect with the 3.5mm cable and sound great.
I have another setup that came with a subwoofer that is just dynamite for the Barn work areas with the bigger sound. YMMV.
rlitman
Long Island
Any reason you're stuck on bluetooth? I use an Amazon Echo Dot in my garage, and it'w WiFi.
I have the old $20 Echo Dot with a crappy speaker, but it has a 1/8" stereo jack, which I use to run a decent set of computer speakers. It gets internet radio, and I use it to voice control a number of switches in my garage like:
Alexa, turn on coolmate, or
Alexa, turn on compressor, or
ALEXA TURN OFF DUST COLLECTOR ;)
R
R-mm
Thanks all, lots of great ideas in here. As a very very happy user of bose computer speakers (lots of clear sound, small package, quality materials) I'm wondering if there are any users of Bose's soundlink or similar BT speakers? yes these are mostly over $100 but I might look on CL or bust the budget for something I'd keep a while (computer speakers still going strong, looking great 10 years on)
https://www.bose.com/en_us/products/speakers/portable_speakers.html
R
R-mm
I see a few deals on older Bose Wave radios. Can anyone say if the various bluetooth adapters work seamlessly (as thought the function was built into the radio) or do you have to start them, charge them, etc ?
jd_1138
NE Ohio
I guess you could find a bluetooth connector that you can leave plugged into the wall AC all the time so you won't have to worry about charging it.
Or just plug your phone straight into the radio via the audio jack if your phone has an audio out.
If you do get a smart speaker like a Google Home Mini or Amazon Echo, you can control it with your phone anywhere. Won't need the phone plugged in and that wouldn't rely on Bluetooth which can be flaky. Instead it would run off your wi-fi for Pandora, podcasts, etc..
ChaseDE
Delaware
To be fair to Amazon Alexa, it CAN also be used as a bluetooth speaker, it can connect to your phone via bluetooth.
Bighead38
Rockland County NY
I got a ihome speaker as gift and leave it in the garage. Has Bluetooth, radio, and alarm clock. Also changes colors lol. I just wish it went a little louder because I work in the driveway and like music cranked up when I’m working. Probably better it doesn’t though because the neighbors would hear it.
rlitman
Long Island
I have a SoundTouch 10 that does bluetooth, but I use it on WiFi much more. The sound is EXCELLENT (as can be expected with a Bose product), but the interface is so-so.
Citation
Indy
The old Bose Roommate powered speakers plus am Amazon Echo Input could work nicely. As others said, the Echo has BT built in and you can simply tell it to connect to your phone. Roommate speakers vary in price but I've found them on eBay for under $50. They aren't my first choice but they are decent. Like a lot of bose stuff they sound pleasant vs really good but at less than fill price they are a good option.
blacksporty
So Cal
I didn't chime it due to your price point but I have this Bose https://www.amazon.com/Bose-SoundLink-Bluetooth-Speaker-III/dp/B00HWSXVDG/ref=sr_1_26?gclid=CjwKCAjwldHsBRAoEiwAd0JybWchnIO2YzDloMse6Ka9eitIQ6MQu6ED-zg4kUV-szl19Lv-r6YAcRoC8vAQAvD_BwE&hvadid=323590276057&hvdev=c&hvlocphy=9031532&hvnetw=g&hvpos=1t1&hvqmt=b&hvrand=3526137832959513977&hvtargid=kwd-421989056386&hydadcr=5028_10685375&keywords=bose+blue+speakers+bluetooth&qid=1570039619&s=gateway&sr=8-26 Thay my wife got me for Xmas several years ago, I would not have spent that much but I love it. It sits on a charging dock on my bench but if I am working in the yard I just pick it up and go. Sounds great.
I also have this one that I keep in the RV https://www.amazon.com/ION-Audio-Block-Rocker-Plus/dp/B07C32XSH1/ref=sr_1_2?gclid=CjwKCAjwldHsBRAoEiwAd0JybV4jHz_1K0Uc_Z58p9SwGkV_XxrCkbYy9NTcTavWaEoE5lQYIVTkVhoC0fUQAvD_BwE&hvadid=323492220652&hvdev=c&hvlocphy=9031532&hvnetw=g&hvpos=1t1&hvqmt=b&hvrand=18328979056438623059&hvtargid=kwd-400264653248&hydadcr=5658_10674171&keywords=ion+speaker+gameday&qid=1570039828&s=gateway&sr=8-2 Not Bose but works well.
R
R-mm
Got a nice first gen Bose Wave for forty bucks and have a bluetooth thingy and external antenna coming soon. Thanks for advice
R
R-mm
Thought this bt adaptor was a good find for plugging directly into the wall no xtra xformer.
tff
Greer, SC
I have a UE Boom 3 in my garage. Very happy with it... fills my 20 X 30 well, remote on/off/volume from my iPhone.
Oregon Coast
Go to Costco and grab an ION Pathfinder or Job Rocker. I have the ION Job Rocker at work and use it daily, got it for $49.99 on sale one day and it is super loud at work in our Truck Shop. It also has a large battery in it so I can bring it out into the logyard and jam out to tunes while wrenching on the log loaders. I loved it so much I bought the bigger brother, the Pathfinder for $119.99 and use that baby at home. Again, its nice to rock out in the garage and then be able to bring it out in the yard as well. Both are Bluetooth compatible and the FM radio works great as well. Plus if you want to, they have Microphone input so you can sing your coworkers a song!
P0234
NoVA
Amazon Echo (not dot). Sounds great and does lots of useful stuff like math, take notes and skip annoying songs when your hands are full. Can even call for help (not 911).
JPinSTL
Stanton, MO
Does this need to be portable? Or hard mount stationary?
Does it need the radio function, as in FM?
This may or may not work for you but for $60, Bluetooth and AUX input, 120V powered so no batteries, these have been great on our 16x30 covered deck. They crank well for being small in size. Definitely not Bose quality but they've been holding up well for a few months so far. They are outdoor rated, so poly speaker cones, and I would think they should last quite well in a garage that will see temp and humidity swings. I have an old iPhone hooked up to them for MP3 music and it can stream Spotify, etc.
https://www.amazon.com/gp/product/B06XCYK12M/?tag=atomicindus08-20
