Garage Build - 16'x20'
stafford
North Geogia
when you make start a thread or reply to a thread scroll down to the bottom of the page to where it says manage attachments on the left, click on a tab find your pic and select it. I think that will work for you, and good luck with your new build.
Staffird
Z
Ziggs280
Northeast Florida
The the trusses are now on and I am working on the soffits. I have had questions and had no idea about this forum. So if anyone can help please chime in.
I need some ideas for the soffit. I thought about just screening it and using lattic trim but I was wanting something more clean looking. Any ideas?
Z
Ziggs280
Northeast Florida
Soffit question
It's only 6" wide area and once the fascia on it's more like 5". Here is an over all pic.
Z
Ziggs280
Northeast Florida
Overhead door installed
Thanks 1/2 Cup.
I got the overhead door installed today. It was nice to set the subcontractor up and leave for an hour and come back and something was done I didn't have to do! :) but I am really enjoying building it. Just not enough time in the day!
1/2 Cup
Member Emeritus
Shepparton. Victoria. Australia
Re: Overhead door installed
Thanks 1/2 Cup.
I am hearing you, I could do with 48 hours in a day and the weekends are not long enough.
Lots of satisfaction in seeing a build through from start to finish.:thumbup:
Z
Ziggs280
Northeast Florida
Are furring strips behind hardie a good idea? The walls are wood framed. Just wondering if it's better for drainage is any moisture gets behind. Thoughts?
rvieceli
Illinois
Ziggs google rain screen and you'll get lots if info. As always, there a proper way to do stuff. The theory is that having a drainage plane behind the siding allows for proper drying out. A lot of paint failure can be explained by moisture getting behind the siding and then migrating through the siding and popping the paint off.
Z
Ziggs280
Northeast Florida
Any ideas on a gutter system or a way to stop all the splash back? I think gutters would hang funny with the roof pitch?
Z
Ziggs280
Northeast Florida
Starting to paint the trim. Siding paint will come soon. Also about ready to coat the floor. Electrical is done and running my compressed airlines.
captain14
Good looking garage. Nice to see a reasonable size garage going up. What are your plans or projects for the shop? Got a layout for the interior yet?
Post you location in your stats so you can get good answers specific to your location. I see exterior lights so I assume you have electric.
Man door area going to have a deck or landing in front of it? Hard to tell by the photos.
Can we see all four sides? Windows all around?
Z
Ziggs280
Northeast Florida
Thanks guys. Yes it is a roll up door. I recessed it between the joist so it sits just under the attic decking. Worked out well.
I do not know about the deck yet. We have thought about doing something. Right now I just want to get the interior finished so I can move tools in.
I'll try and get some pictures of the over sides. I have the man door on the right with a small window. That is the only window. I wanted to keep as much wall space as I could.
I have three 8' - 2 tube (t-8) strip lights and 3 recess light over the work bench area. I am happy with the amount of lights. There is a 50 amp sub panel that I have three 20 amp circuits (one circuit per wall). I also ran compressor air lines with my compressor in the attic and a switch down stairs to turn it all.
This weekend I am finishing the floors and hope to insulate next week and start finishing the interior walls.
I'll post more pics soon.
racerex
NY
+1 for small garage interior pics.
I'm building a 18'x24" pole barn and I'm also looking for interior layout ideas. I'll have a 9'6" ceiling height and I was debating wood walls, but I think I may just go with 5/8" fire code drywall.
captain14
I see you are in N. Fla. Are you going to install insulation? I not sure about how cold it gets but I imagine it gets hot down there. AC unit or just fans?
Loft upstairs with a pull down set of steps?
If you want wall save for storage , why not OSB board painted? Plenty of spots to hang fasteners, for cabinets and everything else.
Z
Ziggs280
Northeast Florida
I do plan on insulating the walls. Nothing yet for a/c though. I have some tools I want to buy first. I did a ridge vent and have the downstairs vented well to the attic so surprisingly it doesn't get too hot in it.
I have nice storage up stairs. About 5'5" at the peak. I was hoping to have 8' when I was originally designing but local codes wouldn't let me go above my house.
I have been thinking about osb or plywood. I may do that with some other plank wood or something.
Please post wall finish pics soon. I am about a week out from starting that!
captain14
Probably should be painted a light color. Anything dark would make it seem smaller than it is and harder to see inside if not all the light s are on.
What kind of tools do you want to buy? You know the rules, you never have enough tools.
Z
Ziggs280
Northeast Florida
I am looking at purchasing a floor mounted band saw (probably 14"-16") and a belt/disc sander combo. No room in my current garage now but I will in a few weeks.
Z
Ziggs280
Northeast Florida
Worked a little last night. Wired the recess lights, ran some air lines and insulated some more.
Z
Ziggs280
Northeast Florida
Looks like I am going to do a pallet wall - chair rail down on the sides (plywood above). Started a little today.
vartz04
LaSalle County IL
If my next house only has a two car attached garage this is exactly what I want to build size wise for my workshop. Wife's car and kids toys in the attached, work truck in the driveway, and this would be my workshop.
Great work so far
Z
Ziggs280
Northeast Florida
Great work so far
Thanks! That's exactly my set up. Wife's car in the garage with the John Deere and kids toys/bikes. Truck in the drive way and work shop in the back. That's funny.
stereosteveo
Really nice!
I have a 16x20 slab poured now.
Hoping to do something similar.
Z
Ziggs280
Northeast Florida
Update on Garage Build - 16'x20'
Very nice build!
Was that the biggest size you could build?
I could have gone bigger on the foot print but the height I was limited to about 14'6".
Update:
I still haven't finished the inside yet (3 of 4 walls are done). I did get a 17" bandsaw (220) though which has been great. I had 30 cub scouts cutting pinewood derby cars last year in it. I need to get back to the shop though and finish. I am needing to put gutters on the garage now because of splash back at the man door is damaging the wood jambs (should have done composite...). I didn't think through the water shedding off the roof enough. That's the only mistake I am not happen with thus far.
The compressed air lines are run just need to finish hooking the compressor up in the attic.
We are starting to build a boy scout garage at the church Friday so finishing the garage is pushed back another month... :(
