Garage Door Help
Mustangmike66
Wasilla, Alaska
I am mocking up my garage door before I do the final install. I found that my door is 1 1/2" too short. I thought about thickening my slab (when I pour it) or maybe even installing an extra panel. Both of these options are going to cost extra. Or, I can lower the 2x6 nailer for the track that I am going to nail on the inside. It will stick down 2" below my buckboard. What would you guys suggest? I don't think it will look bad after it is caulked and painted.
NUTTSGT
Northern Central Ohio
Did you put the building up or have it built ? I don't think the door is too short, I think somebody made the opening to tall.
Spudland_Dave
Maine
Why not simply add another panel :wtf: One panel can't cost that much...
You would be suprised. This spring my Wife/Kid (Equal Blame, but thats between us :evil:) busted the top 2 panels on the attached garage door...figured it wouldnt be a big deal, priced out the 2 panels and it was only $50.00 less then an entirely new door set (all new panels, new rails, new springs, new everything) AND They wouldnt/couldnt even guarantee the replacement panels would match. Not hard to make that decision.
Personally, I'd slap a 2x of whatever width needed to build it down.
Mustangmike66
Wasilla, Alaska
Yes, they are expensive. And think about what they cost in Alaska!
RollUpDoor
If you paid somebody to bulid that opening, they F'd up. Call them back out and rebuild it. If you did it. Just fill it in with a 2x6 and paint it.
Mustangmike66
Wasilla, Alaska
I did it. Kind of hard to get it perfect without a slab. I plan on pouring that next year ball I have now are stem walls and dirt to grade. You can see my project in the gallery.
pattenp
Virginia - USA
nmk_61802
Central IL
Redo the Trim and Jambs around the opening to lower the upper trim board by 2". Add wider trim to the outside, done. No one will ever know.
Mustangmike66
Wasilla, Alaska
I took Pattenp's advice and went to Lowes and got the PVC trim. I used a PVC trim board and then the trim piece with the rubber seal. Not only does it look great, but it's one hell of a seal. Thanks guys!
Mustangmike66
Wasilla, Alaska
I have a question about springs. I have some springs that I purchased second hand and they don't have an insert in the end. I disassembled a unit I had because I wanted to convert it to a two spring set up. This unit had a plastic insert in the end. Do all of the springs need this insert? You can see the black insert on the left.
pattenp
Virginia - USA
Whether you have one spring or two there should be an end bearing or busting on the fixed wall bracket end of the spring.
Like this......,
This is what's used with the black type bushing in your picture.
Mustangmike66
Wasilla, Alaska
I have those. I was curious about the one spring having an insert and the others not. I bolted the springs to the center bracket and all seems well. I was just wondering if the inserts had to be in there before they were bolted to the bracket.
pattenp
Virginia - USA
The black insert is a bushing and is only needed if you use the style of center bracket that doesn't have a built in bearing. The second picture.
Oh... I'm happy my suggestion worked out for fixing the gap at the top of your door.
