Garage Door- High Lift Conversion Help Needed
project_x
Hi All, I have a 8ft door in a 11 ft high garage... I wanted to raise the door to accommodate a 2 post lift.
It was a cheap Stanley uninsulated steel door with a single spring.
I got track and bracket, large capacity drums, longer cables, and two 225 springs...
Track moved and modified to go about 21" higher. The door moves smoothly on the track.
Drums and torsion springs replaced.
Cables installed.
I wound the torsion springs to 30 turns each.
When I removed the rods...the door went up 3ft....
the first two feet is seems to run fine.... but after that it is impossible to raise without a lot of work....
I am clearly missing something.....
Any thoughts?
Disclaimer: I have experience with wind bars, torsion springs and adjusting the safely.
pattenp
Virginia - USA
Not enough info. What's the door weight? What is the exact drum style you have, are they stepped? How did you determine the spring size to get. Just based on your description of how the door is doing makes me think drums and springs are mismatched.
Uncle murph
Harford county
Hi All, I have a 7ft door in a 10 ft high garage... I wanted to raise the door to accommodate a 2 post lift.
Cables installed.
I adjusted the cables to be closer to the floor....
Any thoughts?
If I understand correctly what you have changed,you should have wound the spring 38 times.
Jogyver62
Oak Forest IL
I have a gable roof that’s parallel to my garage door opening. I redesigned the garage door tracks and add 600# springs. The garage door follows the roof now. I did add one post to support the loft for storage
firebirdparts
Kingsport, TN
Cables installed.
Any thoughts?
In normal doors, the door goes from 100% weight on the springs to basically zero linearly from closed to open. Spring force is linear with movement. This requires a basic constant diameter drum to work. They use a special shape drum to modify this math for a high lift door, but you only get one format for that. You can’t just buy a drum for every set of tracks.
What you are describing is a high lift door with regular drums.
jstroede
Kansas City
Cables installed.
Any thoughts?
Need to know exactly what all parts you have. What you have said indicates too much spring and not enough turns.
Need exact spring size
Cable length
Drum size (400-54?)
When you say you adjusted the cables to be closer to the floor, what does that mean?
Also, what overall size and model is the door?
John
P
project_x
Cable length
Drum size (400-54?)
John
Spring is here, and I am back on this. Sorry for the delay, for some reason I didn't get any notifications of responses.
I have an 9ftx8ft door, stanley, steel weighs 100lbs
I have two 400-54 drums, cable length is 11ft 4".
I have raised the track 21" from where it was previously.
15" radius
I have two 2" 225 springs 2" diameter 30"long (I got them for free and would change them out if needed...)
Boatman62
This is interesting. I had a high lift door installed a few years ago along with a couple regular lift doors. The high lift does exactly what the OP describes. I questioned the installer and got " just the nature of the beast". It has the same drums as the other doors.
racecougar
Missouri
Sounds like you do not have the correct drums in place for a high clearance/lift door then. The typical "high lift" arrangement will have drums that look like these:
jmdirk
15" radius
How many wraps of cable on the drum in the closed position?
Still not sure what you mean when you said that you adjusted the cables to be closer to the floor?
But initially, door opened automatically, which means too much tension/too much spring.
After your adjustment, opens fine at first and as you lose tension, door gets hard to open. Which sounds like your not in the high lift portion of the drum anymore and maybe have too much cable on your drums? Sounds like your cables might be too long?
AndyL
Vancouver
15" radius
Normally I'd say you're nuts mixing and matching random parts...
Single spring 218x2x28.75 appears to work.
225 - you'd need 33" also single spring.
Use the cable length formula for whatever drum you're using, it's not a guessing scenario - it's floor to shaft measurement, and some basic math.
P
project_x
I have 1/2 wrap.
I don't recall what I meant by adjusting.... to be closer to the floor... I will remove it from the original post
P
project_x
Thanks Andy.
Where does one find these calculations? I have a 400-54 drum, 8ft door, 21" lift what should the cable length be?
AndyL
Vancouver
Floor ->shaft center +63"-highlift is the canimex 400-54 book calculation; you'd need to put a tape measure on yours, verify if your drums are equivalent and do the math.
Note you're using "turns" in a different format than I am - I'm assuming you mean 1/4s, as you'd never get 38 turns on that spring, but 38 quarters makes sense.
P
project_x
I meant quarter turns...
My shaft center is 129.5" so my cable should be 129.5"+63"-21"( highlift)=171.5" (I have 400-54 drums)
Now with my 100lb door, what is the ideal spring or springs to install?
firebirdparts
Kingsport, TN
That's a harder question. You should easily be able to figure out, now, with it all assembled, just exactly how many turns the shaft makes during door movement, and what the radius of the drum is when the door is closed (it should be on the variable radius part). So you'll want spring(s) having torque just right to offset the door weight with about that many turns. So none of us here is quite willing to figure out how many turns you'll have and the radius, but you can observe that.
p00p
42.4974° N, 82.8964° W
Where can these be bought online to the general public without buying an entire kit? I'm assuming these type of drums are left & right specific?
racecougar
Missouri
A quick Google search turns up a bunch of retailers that will sell you the drums separately:
p00p
I wasn't so sure if I'd run into a road block like I have in the past (& current) for other garage door parts a la carte'. IE: High Lift track parts & replacement springs. Note* I was successful procuring the springs & am still looking for the unique IIRC 45 degree tracking where the door rolls thru the bend.
racecougar
Missouri
What portion of track are you referring to?
jstroede
Kansas City
Turns on the spring and turns the shaft make are two different things. Your springs will always have more turns than your shaft makes to operate the door.
AndyL listed the springs in a reply above.
John
jstroede
Kansas City
Yes what are you looking for exactly? are you trying to make a roof pitch? If so, you just cut material out of the radius.
John
