Hi All, I have a 8ft door in a 11 ft high garage... I wanted to raise the door to accommodate a 2 post lift.
It was a cheap Stanley uninsulated steel door with a single spring.
I got track and bracket, large capacity drums, longer cables, and two 225 springs...
Track moved and modified to go about 21" higher. The door moves smoothly on the track.
Drums and torsion springs replaced.
Cables installed.
I wound the torsion springs to 30 turns each.
When I removed the rods...the door went up 3ft....
the first two feet is seems to run fine.... but after that it is impossible to raise without a lot of work....
I am clearly missing something.....
Any thoughts?
Disclaimer: I have experience with wind bars, torsion springs and adjusting the safely.
Cables installed.
Any thoughts?
