garage door insulation
1930artdeco
Lynden, Wa
O.k., the search thread turned up a huge amount of threads on this subject. I would like to insulate my garage door to retain heat and keep cool in the summer. I have seen kits at HD for this. Question, how well do these work vs. me cutting to fit my own foam with a foil covering?
Mike
moon29
I was going to go with the kit but ended up buying insulation board and cutting it to fit. I works very well, but I can not compare it to the kit.
I'll upload some pics later if you want.
b_dub
On my double door I did 2 layers of foam, one was a blue foam and the other was the foil backed white stuff.
On my single door I got a kit and it turned out to be a fiber glass batting like you use in the walls only thinner. I used that and also put a layer of the white foam with the foil to make both doors look uniform on the inside.
Either way was about the same.
moon29
here is mine
Falcon67
Merkel, TX
I did two 7x16 doors with 1/2" reflective backed foam. I've done one 8x7 with 1" hard foam insulation. All worked/working very well - I would not see any reason to buy a kit. Kinda help to know how big your door is.
hughfree
Fayetteville, GA
I bought a kit from Lowes.com. Well worth the price. The panels are serrated to make it easier to install in the door panels. Also, the scrim side can be painted.
Mike14k
Very rural Oklahoma
I just did the foamboard, attached with construction adhesive. Works great, but fragile. I wish I had something to cover it with.
Be sure to buy the insulation seal that attach to your door frame. Inexpensive. That helped a lot in the wind leakage.
