garageflunkie
- Joined
- Aug 21, 2023
- Messages
- 16
Hello. I am looking for advice.
I noticed that the garage door opener arm is attached to the pin that goes through the garage door bracket on the outside, and not centered. Can I remove the bracket on the garage door, fill the holes, and realign it? I noticed that if the center rail would have been centered on that piece of wood above the torsion spring, everything would have lined up.
I also was told I should get a center bearing for my single torsion spring, above my single garage door. The broken one above the garage door currently has a nylon bushing. When is a center bearing necessary?
I noticed the slide bar mechanism to lock the door doesn’t line up with a track slot to be able to physically lock the garage door. Should I just remove the mechanism, fill the holes, and remount the slide bar mechanism higher to be able to use it?
The black, plastic wheel I have circled in one of the pictures is damaged that the chain goes around in the center rail. Is that a part that comes with a new garage door opener? If so, great, because I will be installing a new garage door opener.
Thanks in advance.
Thanks in advance.
