CyberWizard
I was an alarm installer in a previous life and I used a LOT of those Amseco type magnetic reed contacts shown by the OP. The one with the aluminum bracket. They work really well at both the bottom and top of a rollup door but up at the top sure makes life a lot simpler when it comes to protecting it from damage. They're armored but not indestructible.
That being said, a lot of doors are sloppy and can cause alarms in a breeze if the installer can't adjust them correctly. A Magnapull like ratdoggy suggested works great in a garage where you don't need to gain access through the rollup door from the outside, like via your remote opener.
The motion sensor recommended by spv is a great idea. It makes for a simple install and isn't as exposed to damage. When it's a multi-tech unit like a PIR/Microwave combination you can avoid the obnoxious falsing when PIR detects rising heat from a warm engine on a cold day. The snag there is that many models of dual-tech motions can be overwhelmed. Detection by PIR and Microwave is required BUT "x" number of triggers from the Microwave alone can cause the sensor to register a valid alarm anyway. In a small garage it's pretty easy for a microwave sensor with a 30' range to pick up things going on outside your walls.
I've use all of the above, including gatchel's method of lacing the door itself (in some cases even lacing walls behind the drywall to cover the whole place for a really paranoid customer). Kynar wire-wrapping wire works well for that as it breaks pretty easily. The best solution is always the one that suits how your using your garage. Security is a really funny thing, and is different for everyone. If you need to use your remote to drive the car in, a magnetic switch is a good start but make sure that you have sufficient time to turn the system off when you pull in. An extended delay zone can make that work. That'll give you loads of time to get out of the car and that time will shorten when you break the interior door zone to get into the house. Back that up with motions and/or acoustic detection if you have another exterior door or window. Put magnapull's on your rolling tool chest or vehicle to ensure that you have additional coverage on anything that can be hauled away.
The bad thing for the thieves is, both wife's know how to handle themselves as well, if not better then the both of us.
. Well over 15K in tools and not one taken , Considered myself lucky . Won't take security quite so likely at the new place even though it seems like a much safer neighborhood.
