Garage door spring just snapped...
jake00
illinois -- NW Burbs
Is this something a pro should replace? It's a 16x7. With a single spring.... I'm pretty competent, but have heard horror stories of about the stored energy in a spring.
sublimate
Colorado
IMHO it's no big deal to replace it yourself if you'd rather. Just take it step by step.
The stored energy is no more than the potential energy of a car raised off the ground - something most of us do often - just with the right precautions. So take similar care and you'll be fine.
Stuart in MN
Minneapolis
It can be done by a homeowner, but if you're not comfortable with the idea hire a garage door company. One of mine snapped a few years ago and since it was -20F that day I hired it out. :) It really wasn't that expensive, and he had the work done in about 20 minutes.
gnpenning
I have more questions than answers.
You can do it yourself. Just be real smart about what you do. You will need to know the inside dia of the spring, the length, and wire size to get the new spring. Also if it is a left or right hand wound spring. With one spring you can get either side but need to put it on the correct side when you install.
MAke sure your winding bars fit snug in the holes. Run a line of paint down the spring to help keep track of your winds.
CTyankee
CT
I did a small one on an enclosed trailer ramp door once. I'd leave the garage door one to a professional.
Want2race
Watch YouTube and decide if your comfortable.
The logic is simple- don't let go of the tensioning stick and don't put your face or body in line with it.
Garageguy65
Spokane WA
Jake. If you have a pro do it ask them to replace the spring with extended cycle springs. While the normal cycle springs may be 15000 cycles. The extended cycle springs may be 25000. They are not that much more.
CNGsaves
KS and OK
Need more information . . . . What kind of door ?? Typical steel (either insulated or uninsulated)?? Or very heavy wood ??
What are your plans?? If upgrading garage door in future (ie heavier), then go with 2 springs rather than just one.
NEED PICS . . . . Let's SEE what you've got.
:needpics:
J
jake00
It's an insulated door. Called the number on the door (I'm guessing last people to fix it ). For 175 an hour they'll come now.... I'm cool w paying normal rates tomorow.
Greeny
Shreveport, LA
I just replaced my springs a couple weeks ago. My door has two. Watched a couple youtube videos, including how to identify the spring size, diameter and length, ordered them off ebay, and swapped them out in about 90 minutes. Several videos mentioned replacing single springs with double springs. Wasn't difficult, just followed the basic safety info found on the videos. I wouldn't hesitate to do it again.
Ponchoguy
When I redid my garage, I went with old style torsion springs, they are easy to replace and safer.
Just be careful with those wind up springs. Those things mean business.
kbs2244
It is a comfort level thing.
Do you feel OK learning how to replace a spark plug on a lawn mower?
If not, hire a guy that knows what he is doing.
Do you have a feel adventure?
Then go for it.
I am 71 years old.
My father was WW II Aircraft carrier airplane mechanic.
“Patch them and fly them.”
He taught me a lot.
I pulled down my first V8 at 14.
I am comfortable taking on many projects.
I also call in the pro when I think I may be over my head.
There is a huge amount of knowldge shared on the intenet these days.
Make use of it.
Todd.Brock
Cincinnati
This is one area where I have yet to tackle. We were on vacation and mom was house sitting. Either 189 or 289. I don't recall which. 2007. My gut says phone it in.
LifeLongWNYer
South of Rochester, NY
A normal garage door spring replacement is not a problem if you move slowly and don't try to rush it. I've done quite a few of the stretch type springs ( run along side and parallel to track ) and a couple of the torsion type, with no problems.
However I once worked for the highway department and watched a guy replace the torsion spring in a 16' wide x 14' high door. It went well until he was nearing the end of winding the spring up. One of the winding bars slipped out of his hand and the spring unwound itself. The other bar punctured a hole in the back wall of the building ( thin sheet metal shell ) and was on the ground behind the building. No injuries, but it sure cranked up our heart rate.
JBP
HICKS
Colorado Springs, CO
It's very simple to do. After you do it, you'll wonder why you even thought of calling someone. Save some money and hit up the you tube.
maxpower_hd
Massachusetts
The spring mechanism is called an operator. There are videos and walk throughs for different types of springs on line. I have never done a garage door one but I have done a couple of tractor trailer ones. They do have a lot of tension once they are wound but they typically come unwound and then you wind them after they are hung in place.
They aren't particularly hard to do but there are some safety precautions you should take. They make actual winding bars just for this purpose and sometimes they are threaded so the can't fall out like one post described. We use two bars one to start and brace against the wall (or in our case the door from inside the trailer) and the second to start winding. And you switch between the two until you reach the right tension. There is usually some sort of rule of thumb from the manufacturer of the operator. Some say x number of turns, some say to paint a stripe on the spring and count the lines as it turns until you reach x. Some say to lift the door after every so many turns and stop when it stays in position rather than raising or dropping on its own, etc.
All that being said, I use cold rolled steel. I bought mine at a local store 1/2" x 36" long and I cut it in half and tapered the ends a little so they fit well. You run the chance of them falling out but if you are careful and don't let go unless it is braced up against the wall it works fine. I haven't had one fall out yet. But the holes in ours are threaded and the actual bars are too so they can't fall out. I'm assuming that is for a reason. Personally I would be comfortable doing it myself. Just make sure you do enough research on yours so you fully understand the risks and can easily mitigate them.
Good luck.
