Skyking1992
- Joined
- Sep 16, 2006
- Messages
- 478
At my Mothers house, the garage door sits high on one end. The slab appears to be level, but the door sits about 1/2 to 3/4 of an inch high on one end.
I disconnected the opener and the door is balanced pretty well and will sit mid travel on its own.
So I thought this would be a simple job of taking a little tension off the high side. The springs are torsion springs, but unlike the modern springs I'm used to seeing. There is one spring on each side, with no shaft connecting the two sides. The spring is probably twice the diameter of the springs I'm used to seeing - maybe 8 inches in diameter.
I don't see any tension adjustment. Any ideas?
House was built approx early 50's. Door is 16 feet and is wood. I'll try to get a picture tomorrow.
![20181025_153809[1].jpg 20181025_153809[1].jpg](https://www.garagejournal.com/forum/data/attachments/686/686050-60c887baddd74c65b340bda320a33d2b.jpg)
![20181025_153836[1].jpg 20181025_153836[1].jpg](https://www.garagejournal.com/forum/data/attachments/686/686090-c477d492d4d2835387cc24033da3c70b.jpg)
