Garage floor tiling on the cheap
Gerald O
NC
It has come time to divert focus from my new shop to give some attention to my old garage -- the original smaller garage built in to the house. I wanted to clean up the storage in here to make more room and improve the looks. I decided to replace the old random collection of open racks and shelving with an integrated metal storage wall from NewAge Products. This would need to be done while working around the existing stuff stored in here.
The first step would be to relocate the vehicles parked in here over to the shop. Not a problem since they're all small.
When I got the vehicles out and thought about putting shiny new cabinets in I realized that something needed to be done about this ugly, stained floor. I wanted cheap and durable (don't we all?). A review on my options came down to installing ceramic tile as the best balance of most durable solution for the cheapest price.
But all the old storage shelving and contents had to remain since there was no more room to move them elsewhere. So the scheme is to work on on one side of the garage at a time.
Preparation was to pressure wash and inspect for high spots. The edges of the slab needed to be ground down a bit here and there, and the expansion joint felt trimmed down.
Day 1
I settled on some cheap 13" x 13" floor tile I found at Lowes for $0.69 per sqft. 500 sqft of this came to $370. Then there was another $170 for 10 bags of latex modified thinset mortar. Total so far $540. I haven't shopped for the grout yet, so that will be additional.
G
Gerald O
NC
There are tooled control joints in the slab, but after 14 years it has never cracked in these. So I'm betting on the odds that it would have by now if it's ever going to. Based on this, I just filled the control joint grooves with sanded mortar for a level surface and started tiling.
Day 2 progress.
A Schluter Reno wedge shaped aluminum trim was used to finish the edge of the tile to prevent damage. I left one tile out where the trim will join another piece when I do the other half of the garage.
While I was tiling this half, the cabinets showed up. So juggling contents around the garage just got a little bit more complicated. My plan is to completely finish this side, including grout. Then move everything over and start on the other side.
dittle fart around
Vancouver, Washington, USA
Make sure you post up pictures once you get your cabinets installed. With NewAge only available online, customers reviews and photos help with customers who would rather see them in person before committing to their purchase.
Thanks:beer:
John
G
Gerald O
NC
Do those NewAge cabinets come Assembled??
Yes. Fully assembled. They are welded construction. The 'Pro 3.0' style that I got are very heavy duty construction, like what you'd find in a quality high end tool box.
G
Gerald O
NC
Day 3
Tiles on this side all set including the cut edge pieces. Ready for grouting, after a bit more cleanup of excess mortar in the joints. I'm thinking I should go with a dark colored grout to hide future stains. What say you?
trashmanssd
Ma
Looks awesome so far, keep the updates coming. I am with you on darker grout its the lowest area and lot stuff will pool there so dark will hide more stuff.
G
Gerald O
NC
Day 4 and 5
This side done now. I used a dark brown sanded grout, then sealed the floor with Zep floor sealer. Next I'll put up some of the cabinets on the back wall, then begin moving everything over to this side to clear the other side for tiling.
brewster55
that looks really nice. im a big fan of the exposed brick too. all i have is boring cylinder block in my house and shop.
G
Gerald O
NC
One problem with the brick was that it has a lot of loose 'crumbs' flaking off whenever you brush against it. So I ended up painting a coat of the floor sealer on the brick too. I might need to give it another coat as it sucked up the first coat like a sponge.
G
Gerald O
NC
Made a small bit of progress, but the cold weather has slowed me down. Cabinets are up on the tiled side. The brick stem wall in the back wall juts into the garage by 4". I wanted to mount the cabinets against the wall so I had to raise them up 9" and set the back side up on the ledge. Then I made some 6" extensions for the leveling feet in the front.
G
Gerald O
NC
How'd you make the extensions?:thumbup:
The extensions are made from 1-1/4" EMT, some M10 1.5 thread nuts & bolts, and 1-3/8" flat washers. I welded the nuts and bolts to the flat washers, then welded the washers into the ends of the EMT. Bolt end screws into the cabinet base, and the nut end receives the adjuster feet.
It was a cheap solution materials-wise, but time consuming. An alternative I had thought of would have been to use press-in threaded pipe end inserts. But I couldn't find any to fit the metric threaded adjuster feet that came with the cabinets. I would have had to buy all new SAE threaded feet and the pipe inserts, and a different tubing size, which would have been very costly.
I have to make another half dozen of them for the rest of the cabinets, so I'll take some photos of the construction next time.
Looks really good
Thanks gasserdan.
I think we have a machinist in the garage!
In truth I only spun them up in the lathe to clean up the tubing with a bit of scotchbrite pad.
G
Gerald O
NC
Getting all the garage contents shifted over to the other side. The new cabinets swallowed up a a lot of stuff. I'll probably tile this side in two sections, front and back, instead of all at once.
Toomanytools?
Washington
Looks good, it's such a pain moving stuff to do the floor at least your space doesn't have too much stuff. Like the Triumph.
I almost went with tile in my wood shop but it's almost 1000Sqft, I couldn't find enough tile in the below dollar range. Plus I wasn't too excited being on my knees for that much tile.
Keep us posted.
Nouniard
Virginia
Do you have a link to the tile you purchased? Considering the same project up here just a bit north of you. I’ll have to do the whole “shift everything to one side” bit too.
G
Gerald O
NC
Sorry, no updates. It looks like I may be waiting for spring to get back to it because of the cold temps. This garage isn't heated or insulated. Plus I had to park one of my cars in here that has high performance summer tires that can't be left outside in below freezing temperatures.
I've moved on to working on Christmas present projects in my warm, heated workshop loft. Right now I'm refurbishing an old 1960s stereo phonograph console for my daughter.
I don't have a link to the tile but you can find it on the Lowes.com website as Project Source Devanna Beige Ceramic Floor Tile 13" x 13". Still showing priced at $0.69/ sqft.
G
Gerald O
NC
I would love to see some pics of the progress.
Sorry Dakota, haven't visited the thread and didn't see this.
I picked up this Sears Silvertone console for $50 on craigslist last fall. Since it came with about 50 records that alone made it worth the price.
Everything worked, but barely. I had to replace the cartridge in the turntable, and had to refurbish the idler/drive wheel since the rubber was dried out and hard, causing it to slip. The amplifier had to be re-capped as the old electrolytics had leaked and dried out. It sounds good now. The cabinetry just needed a good cleaning and polish.
I set it up in my daughter's apartment at Christmas and made some oak mounts to attach their flat screen to the back. There are RCA jacks on the back for "tape" input, so they were able to connect their TV sound output to the console. Still need to stain the TV mounts to match the walnut cabinet.
G
Gerald O
NC
Finally getting around to tiling the rest of the garage. Between rearranging, floor prep, and my general slowness, it took about a week to get this far (I've since got all the tile down except for the cut pieces around the perimeter.)
Carefully combing the thinset to insure even thickness and minimize lippage. I'm using a 1/4 x 1/4 x 3/8 notched trowel at about 45 degrees. Collapses to about 1/8" thickness of mortar when the tile is placed.
G
Gerald O
NC
Wet tile saw is fast, but makes a mess. So I put up a tarp to catch the back spray.
G
Gerald O
NC
Done!
Total cost including grout and sealer came to less than $600 for about 460 sqft. Less if I didn't count the one extra full carton of tile and two unopened bags of thinset left over.
Just got the sealer coat on today.
Now it's on to refreshing the wall paint and installing cabinets.
Angelfire
New Mexico and Ireland
Well Done! Another porcelain garage....love it. I'm sure you're thrilled to be done or at least your knees are. I recently finished mine too and was like a little kid in a candy shop when I finally finished.
Cheers.
Dakota00
Woodbridge, Ontario
Gerald,
That console stereo turned out gorgeous man, nice job!
Also your floor looks fantastic, nice to see another porcelain tiled garage floor completed.
G
Gerald O
NC
Thanks everyone. Technically, it is not porcelain but rather a low cost glazed ceramic. Much like Jack Olsen's garage tile. Not as durable as true porcelain, but tough enough for car parking.
Sean, the tile itself was $0.69 per square foot.
G
Gerald O
NC
Cheers.
Thanks, I wish I were done...
This was just practice for the bigger shop. That's going to be about 700 square feet of 24"x24" through body porcelain. Each tile weighs 20lbs.
Angelfire
oh, have fun with that! I just did my 640SF in 12x24. Weight of the tile wasn't a problem but my tiles had a slight bow in them so I fought with lippage. That and I'm sure I didn't get the floor as flat as I should have. Still came out pretty good though.
Good luck with it!
Cheers.
G
Gerald O
NC
Cabinets all in.
I still have to stow some junk remaining on the old shelves and get rid of them before the floor is completely clear.
