tmcdonal
I hate it when someone comes on to a forum and obviously hasn't used the search function before asking questions. I've been reading articles here and elsewhere like crazy and I have a few remaining things where I'm unclear, so here goes my first post...
I have a detached garage (approx. 4 cars), which is being walled off to provide me with a 16' x 22' workshop. It's finished, with outlets every 6' approximately 4' off the ground. It has an attic space and is currently all wired off a single 20A circuit from the main house with 12/2 NM-B through the header studs in series. None of the romax is in any conduit and it's not required in this open air area.
I had an electrician run a new 100A subpanel here and I'm now planning how to change the wiring. The panel does not have a main disconnect, so part of my planning is staying under 6 throws to kill all circuits.
I'm planning:
- 20 amp multiwire branch circuit from the ceiling to two dedicated 20A outlets powering a dust collector and table saw
- 20 amp circuit to power a refrigerator, 2nd upright freezer, remaining wall outlets outside of the shop, and garage door opener.
- 20 amp circuit to power a wall of outlets and where my workbench is
- 20 amp circuit to power a wall of outlets where misc. power tools are (bandsaw, drill press, sander, scroll saw.) These will not be used concurrently.
- 20 amp circuit for the lights (surface mounted T8 fluorescents, permanently wired)
- 20 amp circuit dedicated for 120V Dual split A/C-Heater
My questions:
1) I'm seeing conflicting interpretations of GFCI being required if not "readily accessible". The ceiling is 8' tall. There's an outlet where the garage door opener is. Does that need to be GFCI protected? Also, behind the upright freezer and refrigerator?
2) I'm clear on the wiring of the multiwire branch circuit. Since they are dedicated and from the ceiling, is GFCI required here?
3) I'm planning on using 12/3 for the multiwire branch circuit and 12/2 for everything (which I'll just call romax for both.) The top of the new subpanel is about 27" from the ceiling. Technically, I could secure the romax to the wall and run them through the ceiling, but I don't like that look. Is there any issue with running a couple of runs of rigid PVC from the subpanel through the ceiling without a j-box? These would just be for protection and not complete conduit system.
Anything else I might be missing from what I described? Thanks.
-Tom
I'm planning:
My questions:
-Tom
