Garage heater electrical question?
J_weezy
Jack D
Southwest Connecticut
I put up a similar heater to the one you are using but it was branded by Northern Tool and I used an Aube electric/electronic relay. to control the 220v from a smart wifi thermostat. Your heater is 5000w and uses 21.5 amps and this works because it supplies 22 amps max.
I actually installed the Aube in the base of the heater and ran out a 18/3 thermostat wire to the thermostat in the area that I wanted to sense the heat.
