garage heater wont go below 68 degrees
JMToolCo
anyone else have a comfort zone cz230e electric garage heater, the digital thermostat on mine wont let me set it below 68 degrees. this seems ridiculous so i did some research and ive seen ppl mention they can set theirs to 45 degrees. id appreciate any insight or personal experience
6768rogues
Western NY
Not familiar with your heater or thermostat, but if it is a line voltage wall thermostat or if you can adapt it to use a wall thermostat, I would replace it with a regular thermostat that turns down lower.
J
JMToolCo
integrating a wifi thermostat is what i would love to do, im still researching it so if anyone has done something similar or have a good link to some info im all ears
J
JMToolCo
Milton Shaw
See if there are any dip switches that set the range of the thermostat. A lot of PTAC units in hotel motels have limits so that they cannot be set above 76 or below 68 to keep the room in a comfort range. Those also usually have also have freeze sentinel settings that turn the unit on even if it is completely off to keep the room from freezing. Those are usually set at 40 degrees. Motels clerks used to have to go by usually sometime after midnight when the clerk remembered it to turn on units in unoccupied rooms to keep them from freezing.
not sure
How well does that heater work? How big is your space and how much you think it costs to operate? Looks like nice unit
Sent from my LM-Q610(FGN) using Tapatalk
Pruittx2
Points to middle of right palm, Michigan
I have that same heater. there is a way to run your own thermostat and bypass the internal one. Mine will go down to 45, so there must be and issue with yours.
These heaters are rated at 27500 BTU
7500 watts for 1 hr is 7.5 kilowatt hours, MY ele co charges $.012 per KWH.
for 5 hr's of usage it cost $4.50
Here's a great cost per usage calculator.
http://energyusecalculator.com/electricity_spaceheater.htm
J
JMToolCo
thanks for the info, does yours have a digital thermostat or the dial?
