Frequently,when converting simply inverting the cap will adjust spring pressure.LP has a "bump" to raise the tension while the natural side is sorta countersunk to lower to the 3.5-7 in.range.Read the directions and it's pretty simple and straightforward.
Also,if it's going in the garage,check code on minimum floor clearance,usually 18 inches.The reason being,flammable vapors usually(natural gas excepted) have a specific gravity higher than 1 and getting the appliance off the floor reduces the likelihhod of a fire/explosion from gasoline vapor pooling along the floor.This is the reason gas water heaters in the garage are always sitting on platforms.You also want to be careful while using volatile chemicals for the same reason.
I'm not familiar with the unit you're looking into,but if it's just a garage heater,I'd recommend vent free.99.9% efficient,versus whatever the Carrier is rated.
