Garage Lighting - diagram insude
Adam 442
This is what I have planned for my garage lighting using these fixtures.
http://www.homedepot.ca/product/96-in-t8-double-strip-tandem-light/972616#BVRRWidgetID
For the upper part of the mezzanine I'll just use a row of three as it is only for storage.
The walls and roof are being finished with the ag tuff pvc product, so they will be white. Am I on the right track?
FJ 432
Littleton Colorado
I like it. I might consider moving the second row of lights more south. From your diagram it looks like they will be directly overhead of that vehicle bay. That may be what you want but I would consider it lighting up the side of the vehicle more like the second most south bay.
A
Adam 442
Good point on having them light up the sides of the vehicles. I drew this up in MSpaint, so the distances may not be to scale. :lol:
Steevo
43.49600, -112.04300
When I planned mine out, using fixtures identical to yours, I determined that 5.5~6' between rows was ideal coverage for these fixtures at 12' high. Given that, I placed the outer rows half that distance from side walls, and divided the difference to get 5'-5" row spacing across the center rows.
Then I started moving things to accommodate stuff like pallet racking, added an "L" shaped row in a corner for my workbench, etc.
It worked out very well, giving me full coverage and virtually no shadows.
Broadie
SE Alaska
I've got a very similar situation with the garage I'm building, but I have a 3/12 vaulted ceiling and it's only 1 bay with lots of room all around it. Do you pan on doing hanging lights or will they mount right to the ceiling?
A
Adam 442
I was planning on mounting them to the ceiling and maybe make a rig so they mount level insteasd of on the angle. I wasn't sure yet.
Spudland_Dave
Maine
Short of wiring everything up as a test...how did you determine that?
Debating layout myself now....for the sake of future-proofing, I want to plan on the Lithonia T5's...To be able to spread the fixtures & light more, I'd almost like the 4' version but 20.00 for double is hard to pass up.
http://www.homedepot.com/h_d1/N-5yc1v/R-202665211/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=lithonia+t5&storeId=10051
or
http://www.homedepot.com/h_d1/N-5yc1v/R-202665216/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=lithonia+t5&storeId=10051
BUT for the time being, finances being what they are...may just be T8's which I replace down the road.
Steevo
Based on lumens per square foot, I determined how many tubes I needed, divided by tubes per fixture, and evenly distributed the fixtures.
gopromiller
yeah,I like it. I might consider moving the second row of lights more south. From your diagram
