First post in the lighting section.
I initially received awesome input piggybacking on another thread located here: https://www.garagejournal.com/forum/showthread.php?t=439197
However, now that I am going to finally purchase my lights, I thought it would be better to start my own thread to get final inputs and stop hijacking the other thread created by shubox56 (thanks for letting me post in your thread and inspiring me to create my own layout in excel!).
Per recommendations from @Platonic Solid, I am going with this light: https://www.ledlightingwholesaleinc.com/E5SLB35D4-840-p/e5slb35d4-840.htm?CartID=2
The current planned layout is attached. Ceiling is 9ft. My intent is for each full size square to represent 1 sq ft. Any squares split are intended to be split in half. It's not perfect but I think it's sufficient for planning and material ordering purposes. Since I literally have no idea what I am doing with respect to lighting, I would greatly appreciate any recommendations or input.
I have also never wired a 0-10v dimmer and just realized I need to run a separate purple and grey wire for the dimmer. Can you please tell me what gauge wire the grey and purple wire should be? I plan on running 14 gauge THHN black, white, and ground, along with the purple and grey wire, in 1/2" EMT. Is 1/2" EMT sufficient? Finally, does the purple and grey wire need to go to every fixture? I am assuming yes, but want to double check.
Thanks,
houtan
Thanks,
houtan
