BHR4CE1
Thanks guys. I need to get a video of the door going up and down. It is WAY cool!
Absolutely fantastic pics. Any shots of the outside of the house to see the style? Heck...a little thicker door and you have yourself a "safe room"
What make are these lights? I really like them. I see the uplight, but what is the small slot underneath for?
^WOW! Nothing like having a shower stall big enough for the whole family to shower at once. I guess you can save money on the water bill that way.
Here's a few pics of some of the other bathrooms in the house
I work for a high end plumbing products company, and while I spotted a lot of our competitors products and none of ours, I can really appreciate some of the design choices you've made in your bathrooms. Very cool and not something most people can pull off.
Are you running a tankless water heater for the shower setup above? I can see about 20 GPM worth of fixtures, which can't be easy for a typical residential tank unit to keep up with.
i've revisited this thread numerous times to ogle the pictures - this is just so cool.![]()
What the hell is a potato gun??? Pics?
Actually, no. Our contractor tried to talk me into one, but it just doesn't seem like it would keep up to me. Maybe sometime down the road I might revisit that option. We have twin 75 Gallon hi recovery Rheem units.
Sounds like you've got plenty of volume on tap. If you are using thermostatic valves in your shower you can run into issues trying to pair it up with an a tankless water heater. The water heaters usually won't kick on below a certain flow rate, and the thermostatic valve won't flow very much below a certain temperature, so the two are fighting each other.
My version of the potato gun worked best with a 4" PVC section as the fuel chamber that's about 10" long with a 1.5" barrel about 3' long. 1.5 seconds of hairspray and a bbq pit piezo ignitor wired to 2 screws/bolts as electrodes about 1/8" apart.
This will launch a 1.5 x 3" potato about 200-275 yards - gotta get the hairspray/air mix just right...
My rural 1940's service station outhouse....retrofitted under the stairs using recycled/reclaimed everything...except the new waterless urinal, Also note the vintage "Edison" bulb
How do you like that. They are installing one of those in my upcoming garage remodel. The plumber talked me into it.
Back on topic, your inside outhouse is the best idea I've ever seen. Truly awesome.
LC.
It's working out just fine. It get's occasional use, so maintenance is easy. I just spray with a cheap widow cleaner in a spray bottle every once in a while. I could see them not very good for public use though.
How are you guys dealing with the plumbing?
Are you putting in waste lines that connect to the house sewer line (at a lower elevation than your shop floor)
or are you digging some kind of septic tank / field just for your shop bathroom?
I have a pole barn at a rental house which I retain use of as the landlord - I've thought about adding a bathroom for years - but - being in the suburbs of Detroit - freezing has always been a concern - as well as the hassle of building some kind of septic since the shop is at a lower elevation than the house.
jgabl,
Very nice garage theme, how is your floor holding up? I read an article awhile back about using Copperas to stain the floor and then a water base clear coat. Really like the idea of a greener floor and not using acid.
Still working on getting her to leave van out once it's out....
Pouring cleaners into it can greatly reduce the effectiveness of the trap seal liquid, which needs to be topped off periodically.
what happens if the power goes out while your in there with the door closed? can you disconnect it or just lift it out of the way?Here's another pic of the motorized door.
