garage-pak airlines
JasonK
KS
You can do the same thing with 1/2" cpvc or whatever it's called? My friend who owns a Construction Company made all his air lines with that stuff. I plan to, just haven't made it to that point yet.
Luckydevil
Tampa
:scared: You don't mean plastic pvc pipe do you? I'm not sure what cpvc is???
bdaz442
tennessee
Dont USE PLASTIC!!!! Its a BOMB waiting to explode.
Copper is Cheap , easy to install, and SAFE.
JasonK
KS
Lucky, your right, but Chlorinated Poly (Vinyl Chloride) (CPVC) is diffrent stuff. Much stronger...... Do a search on it, 400 psi. I bet the pipe in the garage - pak is this stuff, I could not find what the pipe is that they use on their site. Either way, my friend has a construction company and used cpvc thru-out his shop.
trovato
Putnam Valley, New York
Jason, I think YOU need to do a search on it. You'll find lots of sources saying NOT to use it with compressed air. Here's one example:
"Can I use CPVC pipe/fittings for compressed air or gases?"
Although some people use CPVC piping for compressed air or gases, we are not aware of any fittings manufacturer that recommends it. We feel it is dangerous and absolutely do not recommend it. Air is much more compressible than are liquids and could therefore cause a violent explosion.
That particular one is from http://www.plumbingworld.com/cpvc.html, but you'll find lots more.
Luckydevil
Tampa
Jason, please don't take what we're saying personal. Everyone here just doesn't want to see anyone get hurt.
Yeah there are some guys that swear by pvc and/or cpvc for compressed air lines. Hell they may even claim to have had them for 10 years. The bottom line is that one small crack or small amount of oil can overtime cause the line to basically turn into a pipe bomb.
byrdman
NC
Before long, we will need another forum category, "Compressed Air Lines". The sticky at the top will read, "why NOT to use PVC despite others' apparent success with it.". :deadhorse
White Chocolate
Sacramento, CA
Why not just use 1/2" copper? Its cheap, easy to work with, available everywhere, and very safe for compressed air. Get a MAPP gas torch from sears, some flux and solder, a cheap tubing cutter and you're ready to go!
MCraven210
Colorado
I have the Garage-Pac in my garage. I am also doing alot of copper pipe work getting my in flour radiant heating system. I did a cost comparasion between the copper pipe and the aluminum pipes of the same size. If I did my air system in copper it would have been aprox. one third cheaper. but taken me two to three times longer to install. My time is worth something so in the end I thoght that it was about the same. The fitting that Garage-Pak use are first class and give you a very profesional look.
Mike
JasonK
KS
Hey, that is fine don't use it. My buddy does and has never had a problem. When I use it I might have a problem. I'll be out what maybe 20.00, and a hell of a story to tell....
krooser
Waupaca, Wisconsin
CPVC...PVC...Dangerous for airlines...plus it doesn't allow the moisture to condense which allows it to drop out of the system...Fast and EZ but not the way to go...
Stuart in MN
Minneapolis
You may be out twenty bucks, or you may be dead. The pressure ratings you've seen for PVC/CPVC are for use with liquids, not compressible gases. If a plastic pipe filled with compressed air is damaged it will catastrophically fail, throwing shrapnel everywhere. Steel or copper lines will just crack and bend a little, and let the air out. There is one brand of ABS plastic pipe I'm aware of that is rated for use with compressed air, but it's expensive and you're not going to find it at Home Depot.
As a professional engineer, I've worked with compressed air systems for more than 25 years. In that time, I've seen the aftermath of CPVC parts used for compressed air lines twice, and it wasn't pretty. Fortunately, in both cases no one was present when the parts blew but it made a hell of a mess, and could well have been lethal if someone had been standing in the right place at the wrong time.
If you do a search of just about any online automotive forum (including this one), you're going to find this same discussion and the responses are going to be the same...don't do it. Like Luckydevil said, we're not saying this stuff to give you a hard time, it's just the way it is.
JasonK
KS
Enough guys..... I will not preach the good or bad word of cpvc anymore..... To tell the truth I actually have 100' of "Goodyear,...oil resistant" air line I use. My garage is only 24' long. I have all the hose I need and then some.
JasonK
KS
Matt - I'm offended you said that of my good friend..... I think he completed his master ninja training. Any explosions from his pcvc air lines, he will be able to karate chop the bits before they enter his body.
mbatarga
GA
Go to the Garage Pak web site and look at the 1 or 2 bay system. On the right side frame, they have a small graphic listing the Cost and Labor comparison. It takes the guess work out of wondering what the systems cost.
Proeliator
Oregon
Awesome setup but just too much dang $$$. Better to use copper and use the money you saved for a fridge to store your beer in :evil:
Proeliator
Oregon
A drawback to that stuff is that its nylon pipe. Sure, its rated for air just like the abs green air pipe they have, but they won't pull heat out of the line like a metal pipe would. Heat dissapation being an important factor of course. Less heat equals less water formation. Still, its an alternative and cheaper than the garage-pak (which uses aluminum pipe I believe).
z28toz06
Connecticut
Garage pak is powder coated aluminum I believe.
paintdaddy
Hampton Georgia
Got a question on the copper lines.Do they corode and if they do what can you do to stop it.The last thing I want is the pipes turning green .
stimpy
troy twshp IL
wash the flux off with water after sweating the connections . you could paint the pipe but . it will hold heat and moisture in the air flow .
imported_banzaitoyota
Williston SC
I still prefer the heat removal capability of Black Iron Pipe. There is no substitute for thermal mass.
Then there is the availability factor, What are you going to do when you want to reconfigure? Run down to Lowes and the Industrial Supply house? And how are you going to insure they are here 3 years from now?
I cant even get product support for a Sirius Orbiter system thats less than a year old.
Roadster
Chicagoland
I agree. The Garage-Pak system is first class.
