Garage re-do / paint suggestion
CT2012
Northeast
Am re-doing my attached 2-car. About to throw on a 2nd coat of paint. Right now I've got a coat of oil primer and 1 coat satin bright white. Figured can't go wrong with white, but man, it's bright. Am now thinking for final coat (or last 2 coats if needed; it's all new greenboard) of a slightly off-white to tone it down a little. Am putting 16' of overhead lighting up when all's done.
Anyone have an all-white walled garage and if so, any regrets?
admranger
Las Vegas, NV
I do. Nope. It's bright and boring, but it's functional. A strip or two would be nice, but I'm not that handy with a paint brush, nor patient enough to do that. I did it on the floor instead (see the link in my signature).
hogdoc
Id Ho
Iam in an all white (flat primer) garage now that was old yellowed drywall before, absolutely no regrets. I work in to little light all day at work, dont need a flashlight at home!
C
CT2012
Northeast
ok, points duly noted. white it is....which is good because i've got 5 gallons left!
my last garage re-do was semi gloss ultra white. this time i toned it down a little with satin ultra white. still pretty darned bright/reflective.
i like the satin or semi gloss finish because it wipes down easier.
after that comes floor. will post pics of when it's all done.
this was my last one, a dream setup for me. pic taken before we moved, too bad i don't have one of it all neat & tidy and dialed in with stuff. has racedeck (garagedeck) floor, pegboard, beer fridge, double insulated block walls (r-10 foam then r-19 batts on walls and ceilings as well as rafters), in-wall 15k watt radiant heater w/fan, 60 amp subpanel, semi gloss white exterior paint all around, tsunamiseal threshold, tons of t8 overhead lighting, huge lighted storage attic upstairs, wall-mounted shelves (i left the 2x6 there which was a french cleat), and a custom built workbench made out of vintage solid oak front entry door and weighed a metric S&$# ton. the squares on the left wall by the way are cork, used to protect wall from bike tires--that's a rubbermaid hanging bike rack system mounted on there.
finished it, enjoyed it for a month or so, and then we moved....go figure....:(
now it's on to next project. much of the good ideas came from this here forum, so thanks for all the tips, photos, etc. i quietly lurk 'round here and take it all in.
