Between 705 & 1200 SQ/FT Garage rebuild
sid
germany
7 years ago o bought my house and was super happy with the garage, finally a place for me to work in, i put a barrel stove in, and was happy.
2 years ago the roof started leaking, the F250 didn't fit through the garage doors, and my project cat didn't fit with the hard top... Planning started, it went from raising the ceiling to tear it all down and start over, back to raising the ceiling again.
Anyway this is what I have:
25x31 size, ceiling height is 8ft, garage doors are 9*7 and everything was in general need of some love
sid
germany
Since the roof would have to get higher, the chimney had to go, it was leaning away from the building, and just took a light tip from the tractor to topple over.
I found this guy living in it
Last weekend was deconstruction day..
That was fun but apparently the garage was built better than i thought, it took a bit to get her naked
sid
germany
Then i started raising the walls by around 3 ft.. it is 3 ft because a 2*6 is 12ft and u get 4 pieces out of it
Oh, as you can see, the front wall between the garage doors didn't survive, it was too wobbly..
This is where I am today:
I have to hurry, the rafters i ordered a few weeks ago should be delivered this week, I'm not planning on installing them myself, i have enough work to do, so i will outsource that part, together with the new garage doors it will be the only part i outsource, the rest i do myself with the help of some friends that know more about construction then i do.
sid
germany
Finally ready for the trusses, can't wait for it to see how it's going to look. Only thing I can work on until the trusses are up is the garage door opening frame and pretty up the block work.
thammel
Maryland
Looks great! I guess you're not planning on a lift with an 11' ceiling height...
  • Like
Reactions: sid
BORING HOP YARD
Boring Oregon
Nice work, you're going to love the difference you feel when you walk into the shop space with the ceiling being raised.
Looking forward to seeing your progress.
Thanks for sharing.
  • Like
Reactions: sid
sid
germany
Well the trusses were delayed, they are supposed to arrive this Thursday.... I hope, i need the garage ready, got to fix the tractor, side-by-side and my car, and do maintenance on the truck... Seems like everything is breaking at the moment
sid
germany
Probably not, but.. its still a possibility.. I'm just worried that the lift be in my way since the garage is pretty small
74Ken
Bowmanville, ON, Canada
If it was me, I would be beefing up that 'post' you made between the garage doors. The verticals should be doubles at least or there will be some unwanted movement over time. Just a thought since you have time.
2Rocky
Since you are dealing with Concrete Block, I'd be interested in seeing how you frame the door openings for the overhead door tracks. Tell us about the fasteners.
While I'm no engineer, the Header looks pretty substantial, and similar in size to what a 16 ft door would use.
  • Like
Reactions: sid
sid
germany
They will be be getting a 2x10 on each side for the garage frame, but it's not a structural post, the header is a one piece, the post is just to attach a garage door to it
sid
germany
One big door was originally the plan, but it was simpler to do 2 doors.
As far as framing, i will frame this out with 2x10 to get the right opening size.
I will use glue and some tapcon screws, originally the frame was also glued and nailed, and it was a pain to remove, so i will do the same ( expect i don't like nails)
I will make some pictures next week
sid
germany
Trusses finally arrived today
And i just ordered the garage doors, and informed the crew that they can put the rafters up asap
Boon
You aren't half assin it, are ya? Looks like good progress and a good plan.
  • Like
Reactions: sid
sid
germany
Trying not to half-*** it, kinda hard since that's my standard process when I'm trying to save money.
I'm still trying to save money, but the garage will be like i imagine it, no matter what it costs, even if i run out of cash and have to pay with credit card, the garage is forever, debt is temporary...
Anyway, 1 day after delivery of the trusses, the Mexican crew came and put them and the sheeting up for 900$ + 100 beer money.
Also ordered the garage doors, should arrive end of next week or the week after, so next week is framing the garage door openings
Here some pictures, I'm really loving it, it feels Soo much roomier with the higher ceiling.
sid
germany
Not making progress as fast as i would like, I'm working on the garage door framing, and decided to farm out the shingles, so those should go up next week, this weekend i plan to finish the door framing, and enclose at least 1 side of the gables.
dmittz
Your making great progress! That added ceiling height will be very nice to have. You Also have a nice pitch on the roof, any plans for attic storage?
sid
germany
Still been busy with the garage, I did squeeze in a few das of vacation, but generally I'm working every day on the garage.
I'll post some inside pictures later, but I got everything rewired, got some ceiling fans installed and I'm using the garage. For emergency projects, since I am neglecting everything that's not an emergency so I can focus on the garage.
Anyway, I got the rear finished and one side, here is a picture, I love it more then I expected.
The windows in the dark grey cinder block wall will be replaced with new white windows and the gutters are also still missing.
October is outside finishing month, I am almost finished with siding the second peak wall, and this weekend I should be working on the front side and maybe finish it
sid
germany
I got the second gable end done!
The 2x12 is for the deck and stairs.. don't know yet how I'm going to do that, but I'll figure it out.
I'm actually working this weekend on the front, lots of trim and detail work around the garage door openings... but I should be done tonight.
Then next Saturday gutters and Sunday will be lazy day where I will spend the day on the sofa drinking beer and watching movies....
Boon
This is a super job. Sure is an awesome work space.
