Above 1200 Sq/FT Garage Refurb®
N
NUTTSGT
Northern Central Ohio
As we get closer to finishing up the drill press, I will be moving on to a few other projects.
I've been wanting to get the 56" box out of the packing. I've also wanted to get a wood top for it. I've considered a butcher block top but didn't want to spend big dollars on it. While looking on Menards website, I found something.
Granted it's Spruce and Pine but it'll work. I will have to trim it to size before it goes on the box. Anyone interested in the SKU and price, maybe this will help.
Jgaz
To further update, here's a few pictures.
Thank you. I should have thought that they would be mag pouch’s and used for mags….duh!
Here is the reason I asked. This is the pack I use for trail work, foot bridge repairs, sign installations, string trimmer work etc. at the park north of Phoenix where I volunteer once a week.
The pack works well. I usually never take it off doing pick and shovel work and being able to carry 3 quarts of water is a big deal during our summers.
The folding saw rides nicely in the pop flare pouch on the left. More tools in the RH pouch
This is the current contents of the tool pouch.
I was looking to get the large handle of the 10 in 1 screw driver out of this pouch and into something shallower than the flare pouch and carry it between the two current pouch’s. Your 1911 mag pouch might just work.
Thank you for the measurements and letting me further derail your thread.
N
NUTTSGT
Glad to help. I'm not sure where I bought them, almost positive it was online though. I believe they might be Condor brand.
Try these guys.
Prospecter
Maine
Then it was like Christmas all over and I opened the box
For those that haven't bought a HF box, it comes on a pallet. To get it off the pallet, HF includes a small ramp in one of the drawers.
For the evening, I slid it over against the wall.
Nice box. Quite an improvement from when I got mine. No ramp back then, and I had to put the wheels on myself.
N
NUTTSGT
Friday started out wrong, not wrong but really ****** I might say. I believe I picked something up from one of the EMS calls my last duty day.
So I finally got some garage time today. I had the wife come out and help guide the drill head on to the column. That sucker is heavy and I just needed a hand with navigation.
I scuffed the top, primed and two coats of paint. The wood burner is kicking to help with the drying.
N
NUTTSGT
Then I had a screw up. I measured for the wood top, even cutting a piece of scrap plywood to make sure the width was correct. Bam, spot on.
Then I measured for length and used the blade to edge of the circular saw show edge distance to set up the Bora edge guide.
I ran into two issues.
One. The distance between the blade and edge are 1 1/2", not 1 1/8. Meaning I cut it short by 3/8" of an inch.
I also realized after cutting the end I measured from wasn't square. So one side was 3/8" short and tapered off to more
There's the end I cut off. Expensive mistake. . . .
N
NUTTSGT
From what I see, you seldom make a mistake. Let it go and move on.
Sorry you are not feeling well. Definitely some miserable bugs out there!
Dude, I make mistakes all the time. I just try to learn from my mistakes.
I feel pretty good today, yesterday, just wore out.
Friday I didn't eat till the wife came home from work. I had a can of Chicken Noodle soup out on the counter and wasn't sure if I should try to eat earlier in the day.
She made some Kraft Macaroni and cheese, I ate about half a bowl, took a shower and laid back in bed. She came in at seven PM and I gave her the remote.
I rolled over went right to sleep. Mr Bones woke me up at 0455 to go outside. I walked around outside for a few and the cold air felt good.. came back in and right back to sleep. I woke up at 0752. By my math, I slept for about 12 1/2 hours.
zanyad
NE Ohio
My Cman framing square I have been using for years, isn't square. I've always figured any wide cuts after measuring were just "me".... Well damn, need to buy another framing square.
You can tune a square. Text and illustration below from https://www.finehomebuilding.com/1996/09/01/tuning-a-framing-square
Framing squares are like levels. You expect them to be reliable and accurate, but they aren’t always. Sometimes a square just isn’t, well, square.
You can check one for accuracy by holding the square’s tongue against the factory edge of a sheet of plywood, as shown in the drawing. Make knife marks in the plywood along the square’s body at both ends. Next, flip the square over. With the tongue held flush to the plywood, the square’s body should line up with the knife marks. If it doesn’t, the gap either at the top or at the bottom will tell you if the square is less than or more than 90°.
If it’s less than 90°, get out your center punch, place the square on an anvil or some other equally hard surface, and give the square one whack on each side at the inside corner. This expands the metal, increasing the angle. Check for square, and repeat the process as necessary until you get to 90°. If the square is more than 90°, use the punch on the outside comer.
ptt49er
Rock Hill, SC
You can square up the framing square with a center punch.
Hopefully the link works.
N
NUTTSGT
Drill press looks great Eric. Can't wait to see in unmasked and in service drilling holes.
I'm considering it done Mike. It's not perfect but looks better than when I got it, except the base repair. Good enough for me.
I need to get the top finished for the 56" box to get an exact layout... Snap on cabinet will need to be raised a couple of inches along with broom, dust pan & bench brush finding a new home. After that rearranging, the drill press will be home.
Prospecter
Maine
Funny thing is.....I found something out that I never noticed.
If you are interested, you can square it up with a hammer and punch.
N
NUTTSGT
Looks good Eric. You've created quite a nice collection of fabrication tools there. Well done. :thumbup:
Thanks Mike.
I've always wanted a well equipped garage for a very long time. It probably all stemmed from looking through the Sears Wishbook as I got beyond just the toys. My garage has been a work in progress for close to 25 years, little by little, bit by bit. I've tried to add a new tool every payday, no matter how small.
I've been working a metric **** ton of OT, the wife doesn't care and why wait till I retire to enjoy it ? I've been eyeballing the new HF Central machinery Press Brake.
If I get that, I'll step up to an air over hydraulic bottle jack as well.
I blame half of my garage dreams on this place.
:beer:
Edited to remove double post.
XJSuperman
Central Iowa
I don't know what you intend on bending, but you might want to take a close look at the SWAG Offroad brake presses. There are several to choose from, but they look great. I've had my eye on one for a bit now. Any excuse to use the press more, right?
N
NUTTSGT
Not really intending to bend anything yet, just building the tool collection for future projects.
I just put an offer in on a PEXTO PX36 finger brake. I don't think my offer is going anywhere but the item is marked as "Last Chance." Salesman has my offer and contact info.
:dunno:
I will check out the SWAG stuff.
N
NUTTSGT
If you spotted the green tool box on the work table and the drawers sitting in the background, you're observant.
While looking for the instructions O/H door and opener, I noticed that my chainsaw tool box was leaking oil. What now ? Apparently the bar oil bottle that was full at 32oz, was now down to a pint or so. . . out the bottle, in the box and out on the shelf.
I pulled everything out and cleaned up the box. I keep an oil pad in the top of the box and glad I did or it would have been worse.
On order is a pack of oil mats from Amazon as I have no more at home. I'll be putting it back together tomorrow when they arrive.
N
NUTTSGT
Nicely arranged wood shop. RAS is such a handy tool when it's dialed in. The work top for your box is looking good.
Thanks.
I love having my RAS. I bought it really "right" close to 30 years, NIB but old stock at Sears. It was found during inventory at the Dayton Sears. Regular price was $499, they had it marked down to $299. When it rang up, the system marked it down again to $199.
N
NUTTSGT
Wood top has been scuffed and sitting on the box now. I've got some running around to do so I will get a picture later.
Next up, get the chainsaw box back in order. I'm out of drawer liners but have a small piece of black carpet left from the US General locker.
Fits just right.
N
NUTTSGT
The old divider was something I whipped up years ago. It was held in place by some silicone caulk. I fabbed up a new one out of some aluminum diamond plate.
One aluminum rivet holds it in place and these are what I used.
N
NUTTSGT
A quick overview of the box for those that have never seen it before.
Top of the box, includes a spare 16" bar on magnets, penetrating oil for bar cleaning and manual.KIMG2261.JPG
First drawer, spare parts, fuel mix and survey tape to mark trees.
Second drawer.
Bottom drawer. An extra 20" chain and a 16" chain for the bar in the top. 25" chains for the MS362 saw. KIMG2266.JPG
N
NUTTSGT
Love this kind of organization.
Grab the saw/case and the tool box and you’ve got what you need where you need it.
What brand was that tool box originally? Looks like it has good slides
Farmhand or whatever the TSC house brand was before Jobsmart.
It's identical to what Waterloo was making for Craftsman at the time.
Decent BB slides.
