You might consider adding a shoe at the bottom where you cut off the extra pins. On my 3830 I find it easy to drag the lower arms when plowing.
I do that sometimes if I catch it before it gets too bad.I don’t see the issue. 20% of its still new. Flip it over and run it![]()
That's awesome suggestion. Thanks.You might consider adding a shoe at the bottom where you cut off the extra pins. On my 3830 I find it easy to drag the lower arms when plowing.
No, I don't believe so. That would include the mount itself.Can't you just cut everything off that hangs below the angle adjustment? I would say that you could go so far as slicing off everything behind the angle adjustment, but that would most likely limit the amount of side to side swing you have. I also assume that you are welding something between your skid steer mount to get a center attachment point for this. You may want to also add some angle braces out to the loader arm positions to make sure the load is pushing back on them. Also, I am sure you have looked yourself and are using some of the production models as reference, but here is a BX on similar to what you are trying to accomplish.
Edit to add, this one is designed to float, and to say that I like this project. I have a BX blade, that I have considered doing the same with.
I thought it might be the JDQA, but couldn't remember what Deer called their proprietary version of the skid steer mount.No, I don't believe so. That would include the mount itself.
I don't have a skid steer mount. I'm using JDQA mounting brackets for the FEL of my 2032R. The plate steel I pick up tomorrow will be in the center of these brackets. The mount will get welded in this location but yes, centered. This is why there will be no angle brackets.
I've referenced literally nothing currently in production. My plan is between my ears and a complete one-off. It will retain some of the factory JD parts so I will be able to replace some parts if need be.
I will nowhere near that $1700 price tag in what I'm doing. I have $150 in the blade/mount. $75 in the mounting brackets. Some of the steel I already have but will be getting a piece of 3/8" plate from the local machine shop I source my steel from.
I think I mentioned in the Show Your New Tools thread that I picked up some more Ernst wrench organizers. I found that I need a few more for the Metric stuff after adding to the smaller 27" box.
I ordered 2 more sets of them and a set of pliers organizers for this box. Jungle truck will be dropping them off today.
Will anything be behind that 1/4" plate for a little extra support?
Not really deep enough.... but they work.How deep is the drawer you have those in Nuttsgt? Would those organizers fit in the shallow drawers on the right side of the 56"?
I bought a piece of 3/8" flat bar for the very purpose of reinforcement.Your work on the attachment plate looks good.
I like the design, and how the loader arms will raise/lower/tilt the plow.
I wasn't sure if the plate will **** up against the FEL structure.
Are you planning to weld some gussets/ribs or something across the back of the plate?
(my ATV plow hits the back of the support with a LOT of force, and I don't have nearly as much horsepower/weight/traction as you have with your JD)
The organizers, one section of them is 10" wide and and the drawer is more or less 12" wide. So yes, width wise it will fit.How deep is the drawer you have those in Nuttsgt? Would those organizers fit in the shallow drawers on the right side of the 56"?
Those Ernst organizers sure clean up a drawer. I wish I would have bought them years ago.Thank you! Pliers drawers are probably next to organize in my toolbox.
I looked at the wire racks and decided I didn't care for them. I believe, if memory serves me correctly, they are also taller.Amen! I started with the PlyWorx wire racks. They were definitely better than nothing - but, that's not saying much. Everything was flopping around and falling over.
I tried a couple of the Ernst and, WOW, what an improvement. When I was going to add more, I mentioned to my wife I was going to order 3 or 4 more. She looked at the plier drawer, measured the Ernst rack, and said "I think you should get 6 more". OK, sure! Hard to argue with that!
Thanks.Nice clean design. The weak spots on my back blade are the angle adjustment holes. They elongate over time due to wear. Some large grade 8 nuts or washers welded over your adjustment holes might be worth the time if you are so inclined.
That will work. If you are going with a fixed blade, you might also just use large bolts through those adjustment holes instead of the usual pins.Thanks.
I will probably drive over to the Deere dealer and order a set of springs. Once I put them on, I'm sure the snow will be done for the year but I want to be able to push some loose dirt/gravel with this as well. The latter is the reason is why the blade may get a permanent weld to hold it in place.
