Bob Heine
Eric, I like the lever handles. Nice to be able to open the door with a knee when hand(s) occupied carrying treasures or covered in filth.
Yes Bob, exactly why I swapped them over many years ago. When the youngest daughter moved back home, she carried our granddaughter along with a bag and whatever else. The main goal was convenience for her but I soon swapped the one on my garage door so when "I" carry stuff in.Eric, I like the lever handles. Nice to be able to open the door with a knee when hand(s) occupied carrying treasures or covered in filth.
This new intake is a TFS piece and it is 1/2"-3/4" taller than the current intake that is on the car, Edelbrock Victor Jr.Oh that new intake looks really nice, when you finish the passes share your times, I bet that car is pretty quick.
JB
One of the best things about your Cobra is it's weight... like nothing compared to even a stripped down (but full interior) car like mine.I completely get that, I certainly don't want to spend the money it would take to the fastest person out there even in a street class. My cobra is a ton of fun and pretty darn fast, but I know there are hundreds of cars in my area that are faster. Oh well, still fun to play around with.
JB
Cam, it's about 7K going through the traps.Eric, what's your RPM going thru the traps?. At 3200lbs and making decent hp (obvious with the mph) I'm surprised your 60 isn't in the low 1.5 range. What size tire are you running?
Ya that's a lot of changes to vet through. Not knowing where you were at thru the traps I thought you might be leaving some gearing on the table and little shorter rear tire might help (if even possible). But you've made really good improvements, that's for sure!.Cam, it's about 7K going through the traps.
I need seat time, more than anything else. The car needs a a little bit of tuning..... It's me.
I swapped out the front tires for a 26" taller tire from a 24.5"tire. That has helped.
The swap to 3" exhaust has helped... working well with the bigger 850 carb.
Like I said, it's me and practice launching the car. Last year it was 1.7-1.8 60' times. I struggled.
I have a ClutchTamer to put in the car but I am working through everything as well. I just put a positive clutch stop in the car the other day. . . That needs tested and adjusted.
I'd like to get everything working together completely before it goes in.... just try to keep too many variables out of the equation all at once.
Basically dropping .15 out of the 60' for now on the first trip to the track, I was pleased. I took the plug out and put the power valve back in... I think (hope) I'm close to where it needs to be.
I did have one 60' that was a 1.57 but I screwed up the shift afterwards. I know the car is capable... it's the driver.
Oh yeah. 26.0 x 10.5 MT ET Street radials.
I've been trying hard to make sure I'm going in the right direction this year. Even if progress is slow, I'm good with that, because I know it's moving forward.Ya that's a lot of changes to vet through. Not knowing where you were at thru the traps I thought you might be leaving some gearing on the table and little shorter rear tire might help (if even possible). But you've made really good improvements, that's for sure!.
I had a new starter put on my 04 Powerstroke 4 months ago, and was shocked at how much faster it spins over, I didn't even think it was bad.
Mine was spinning slower but this engine has more compression than the old one.I had a new starter put on my 04 Powerstroke 4 months ago, and was shocked at how much faster it spins over, I didn't even think it was bad.
As something changes slowly over time, most don't notice the difference.
I'm glad I swapped out the starter.
Yes Bob, just replaceable parts totalled.Eric, so sorry to hear of Justin's accident but so glad to hear replaceable parts were the only things totaled. Not to mention the cage and helmet timing.
Even though the track crew said there wasn't, we believe there was some anti-freeze on the track.That is tough to see, sorry about the wreck, but glad he is just fine otherwise. Any idea why it lost control?
JB
Those are the same style of header gaskets I installed on my camaro. I got one heat cycle on them now and I'll retighten them soon before I crank the camaro up again.
