Garage Sale Score
68 sat
Did the early Saturday morning Bagel run and stopped by a local garage sale. It's a 1982 Honda XR 80 that was covered in dust and was sitting for at least 20 years. Practically brand new after a good clean... Here is the best part. $100...I'm not really a motorcycle guy but am looking forward to getting it running and and having alittle fun...definitely my score of the season...;) BTW,
If anyone knows how to get this thing started I can use all the help that is offered..I know nothing about these things
PA-Buckeye
central PA
That brings back the memories. :)
I had my childhood Honda XL75 still at my parents' place. The neighbor got it up and running for my neices and nephews last summer so they could ride it.
Nice catch!
Toolman12
A thousand miles from erehwon
Please let me be the first to You ****! very nice score hope you get it running. As to that try fresh oil, fresh gas, plug, wires, and battery see where you go from there. Good ludk
jhelrey
MN
You need three things for the motor to run... Oxygen, Fuel, Spark... Without one, you got nothing.
Spark can be a bad plug, wire, kill switch, etc.
Fuel and Air is pretty easy
drmarkr
Tucson
Ok....since you're not going to sell that worthless, non-running POS to me.....
It needs the pilot jet cleaned. Remove the carb, take off the float bowl, and clean things out. The pilot jet is the small (about 3/16" diameter, 1" long) jet that you remove with a straightslot. Remove it, blow it out with compressed air, or better yet use a piece of wire off a wire brush to clean it right. If the bowl is really mucked up, clean everything, including the main jet (hex head right in the center).
Like the others said, fresh oil, fresh gas, clean/re-oil the air filter, and that thing should be good to go. About the only thing that could throw a wrench in the deal is if the tank has rust and needs to be really cleaned well.
And yes, you ****, big time......
MR
marty_p
SE LoUiSiAna
One HELLUVA score, Boss! :beer:
You were in the RIGHT place at the RIGHT time with the RIGHT bill! That was one of the BEST uses of a Ben Franklin that I've ever seen! :thumbup:
68 sat
OK,
I started the tear down and there was rust in the tank. I removed it, cleaned it out the best I could and poured a rust remover I bought at HF in it. It looks like the tank is cleaning out well. What weight oil do I use in it?
cj7365
New Mexico
OK,
If there is still rust in the tank, take some bolt washers rocks but them in there along with some solvent and swish it around, it will help break up the flakes of rust etc.
I bought a 78 KE250 a while back that some one left gas in it for how ever many years, i did not put a liner in the tank i just replaced the fuel filter when it get dirty.
take the carb off and dissamble it soak it in solvent overnite
Dan in Pasadena
Pasadena, CA
I think this score is well beyond a "You ****" and is all the way up to an, I Hate You!" lol.
Congrats. Those bikes were loads of fun.
ZRX1040
Upper Penninsula, MI
I put a zillion miles on one of those in the day. Those things are bullet proof. Use any 10-40 motorcycle oil, not the "energy conserving" car oil. Wally World should have some in the motorcycle part of the automotive aisle. Be careful if you use a wire(VERY SMALL) to clean the jets, easily damaged. Good old spray carb clean will do just fine. Put a cheap in line fuel filter on it too. Worth the coupla bucks.
EDIT: and BTW...You **** ;-p
jzt
Dallas, Tx
Pretty sure compression should be #4.
68 sat
That is my real passion...Its a 68 Satellite that is far removed from the grocery getter I bought a few years ago..Looking for high 11s this summer...No not for sale..
DrB2319
Just saw your username, got it.
Building a 408 for my 69 Dart. Looking to run 11.20s and have it be a an almost daily driver from May to October.
drmarkr
Tucson
An inline fuel filter will be very wise with the tank being rusted. I've rarely had to soak the carb. What condition was the float bowl/float in?? If the low speed jet is really varnished up, spraying it isn't going to cut it. If you're careful with the wire, you aren't going to hurt the jet....
What did the air filter look like?? That's a good indicator of how it was taken care of.
You don't want to sell it to me for $500, eh?? It'll save you all this work you're having to do!! elohel....
Herb
CT
Well, the suckage points are high on this one for sure! I think we need to establish a new phrase other than "You ****" for situations that go far above and beyond the you **** range. Any ideas?
911mike
michigan
I have restored lots of old bikes and if you can find someone with a ultrasonic cleaner have the carb cleaned by them. The main issue is the pilot jet, they are just such a small opening that they clod VERY easily. If your not going to ultrasonic clean the carb then go buy a new pilot jet for $5.00. Check out the carb boots for cracks as they get very brittle in 30 years.
Nuts in the tank with some WD-40 works great and put in a inline filter like the Dr. suggested.
BTW I would take the $500.00 from DR. and run. LOL
68 sat
thanks. I used carb cleaner and blew outb all the ports. It seems to be fine and looks practically brand new but I will have to see once I have it back together. I will probably need some advise on how to get to the pilot jet since I have no idea where it is. I am going to re-paint the exhaust and put her back together this weekend. I'll post a few pics when she is done.
Any suggestions on what to use to polish the rims? They look like thay have alot of life in them but there is some oxidation... TX
drmarkr
Tucson
Do you have the carb off already? See my post above on where the pilot jet is located.
This isn't an XR80, but it's very similar....this is with the carb bowl removed and the carb upside down:
Rims are chromed steel....try some chrome polish, of if they're rusted, some really fine steel wool.
Clean that pilot jet and go ride that thing!!
Moose02
New Jersey Shore
my way of cleaning the tank was small very small rock like from a fish tank a little wd 40 then sealed it up so no leaks then wrapping it up in a lot of blankets and stuff it in the dryer with no heat (and the s.o. not home) turn it on and go have a few cold ones it will clean up real good.
joshmodelskidoo
mid western michigan
clean the needle and seat and blow out all the holes with a bit of compressed air. you might have to let the jets soak for a bit. if you use compressed air on the jets then hold them tight and make sure you can see through them and the hole is round
Thruxton
Virginia
OK,
20W-50, and best if formulated for m/c (aircooled) engines. (Ex Honda MC dealer/ factory trained mech here.)
power wagon
western maine the other alaska
being an addict to garage sales and flea markets , i will be posting here alot, here is my week end find,plus lots of old oil cans, found some old military oil cans
68 sat
Got it running and sold it to my garage for$500in shop credit. Building a 56 desoto hemi and need the resources...
