Setting up my first garage and thought this forum could get me headed in the right direction. The garage is 7000sqft on 1st floor and 5000 sqft on 2nd floor, the 2nd floor is not shown on the floor plan below and will only be used for storage. I am in the process of finishing the install on my 10K Rotary lift and converted all lights in the rotary lift room to LED. My next job is to install the 80gal Air Compressor and plumb in the air lines. My first question is where would you recommend I install the Air compressor - I feel like two locations make sense. I have shown both locations on the floor plan of the shop below - Air here? and Or Air here? - The 1st location is where the compressor sits currently in the pictures on the link below. The 2nd location is next to the outside A/C unit and would require a cover to be built, but luckily a concrete slab already exists there.
Click link to rest of garage pictures
https://plus.google.com/photos/101353832723317690195/albums/6147410934148128193?authkey=CJKi3KrrnKCDFg
The way I see it:
1st location - Pros - more centrally located - already has cover
Cons - noise is closer to work area
2nd location - Pros - moves noise further away
Cons - requires more air line plumbing, requires cover to be built
Thanks for the help,
David
The way I see it:
David
