Garage Shelf Preferences?
notherone
I hate buying pre-made **** shelving, but need something to better organize a garage corner. Do you guys just build your own?
CJ7VFR
Central New Jersey
I used old kitchen cabinets that a neighbor was getting rid of during their kitchen remodel. They are built nice, have doors on them, and they can hold a bunch of stuff in them. And because I installed them with the tops of the cabinets about 3 feet below the ceiling I can store stuff on top of them in bins or just out in the open.
I actually want to get more, so I always keep an eye out for anyone around the neighborhood who is doing any remodeling or has put any cabinets out at the curb. I told my wife to keep a look out for that too and let me know if she sees any.
Jim
N
notherone
I did have old auto parts cabinets once but then the family member decided that they wanted them back :/
LopezBart
Lopez Island, WA
Since the perimeter grows with the linear dimensions of the building, and the area increases as the square of the linear dimension, larger shops really likely need shelving that sticks out from the walls in some areas. I like the racks Costco has had recently, with plastic clad shelving.
Delaware, Ohio
Depends on your needs, but building them yourself is much cheaper and you can get exactly what you need. I like the cabinet idea, but it doesn't work for everything you may need to store.
Caa311
Virginia
I did a locker in the attached garage; that has worked out very well.
And 18' of pallet racking in the corner of the shop.
Wow!!! I have 4 of those cabinets in my garage and never thought of building a platform like that. That creates alot of storage space under the cabinets instead of piling **** on top of them. Great idea.
u2slow
BC
There are corner shelving units available out there.
I have done best with built-in stuff. 2x4s and 1/2" plywood. Let's me keep the floor space open for heavy items, and then go to 2' deep further up the wall for totes and boxed goods
jmiller_2308
Shakopee, MN
I definitely prefer enclosed vs. open shelf; it looks cleaner and it keeps the debris from cutting/grinding/dust off stuff in storage.
For repurposed storage consider looking in the usual craigslist/Facebook marketplace places but also look for an outlet or outfit that sells discounted damaged or discontinued stuff. I've bought damaged cabinets just to salvage doors and hardware to make purpose built cabinets cheaper.
My shop storage currently includes some of the following: (sorry, a bit messier than normal due to 3 projects and winter change over)
  • Purpose built overhead storage that is 8' off the ground and mounted to the ceiling and wall. The cabinet is 12' long 2.5' tall, and 20" deep uninterrupted space with sliding doors to cover the contents. It is positioned such that I can use or stand on my lift to access it and it has lights mounted on its underside to help illuminate around that area of the lift.PXL_20241023_102856958.MP.jpgPXL_20241023_102909610.jpg
  • Reclaimed metal office furniture reconditioned and painted to match my tool chests. I have lateral files for larger longer stuff along with the less wide drawers that I use for smaller collections of stuff. I also use some of the overheads with lights mounted on the wall over a bench. Picture 1 finished Picture 2PXL_20241023_103006097.MP.jpgPXL_20241023_103016417.jpg
  • Reconditioned flat file made into a rolling work surface with additional storage underneath.PXL_20241023_103028350.jpg
  • Large wall cabinets made from plywood with plywood doors.PXL_20241023_103217098.jpg
  • Purpose built miter saw station that includes several drawers, a cabinet to enclose the compressor, and a sink.PXL_20241023_103148029.jpg
  • Some commercial storage solutions. Black cabinets from HF for paint and chemicals, stacking open shelfs are somewhat hidden but likely on the list for improvement.PXL_20241023_102939379.jpgPXL_20241023_102950142.MP.jpg
CraigStu
Blacksburg, Va
Look around for unfinished kitchen cabinets. Roll on a coat of paint and hang them up. If you like white or light tan wood look the on the shelf cabinets at HD or L are also pretty reasonably priced.
63f100eba
I like the idea of cabinets more than having them. I put up about 25 linear feet of 50s-60s metal kitchen overhead cabinets and after a few weeks replaced then with open shelving. couldn't remember which cabinets had what in them. labeling didn't help (me) much because the retrieval process them turned into scanning all the labels to find what I wanted, the occasional ambiguity of label nomenclature where, if the label isn't really specific (and therefore long) the contents aren't clear. then opening the cabinet pulling the item, closing the cabinet. sure that's how cabinets work, but it interfered with getting the tool or supplies. open shelves allowed me to get things faster. dust is a problem. shelves are more forgiving in size/ form factor of what can be stored where, while cabinets strictly enforce their limits.
Skellyii
KC Area
@tarmy
Can't say that I've seen a short sortimo cabinet like that on wheels. I'm currently organizing my garage, so I'll be stealing your idea! ;)
u2slow
BC
I have a set of old/used kitchen  cabinets in the shop also. I struggle to utilize them. Moved them 3 times now. Still not properly populated.
tarmy
Nor Cal
@tarmy
I had a metal welding/plazma cutting top on the cart…that is why the wheels. I got rid of that and built a proper welding table and have a IMG_0242.jpegnew location for those bins is this…
Renegade1LI
long island ny
I have a mix of shop built cabinets and open shelves. Sometimes you need storage for odd size stuff that won't fit in a cabinet. For open shelves I use fir 2x6s, I like that I can span 6' between supports and they're cheap and easy to build.
HogDude
Nebraska
Have loved what you've done with your shop. First time I've seen the bomb hanging from the ceiling. Very Cool. I love that WWII "nose art".
phred
NC
I like cabinets. Better organization and helps keep dust off things. Built all the cabinets, most have pull out slides for the heavier power tools.
Jgaz
I really prefer cabinets with doors or storage spaces that are purpose built.
However, at least for me, there are times when open shelves are the best solution.
These shelves are on the side wall where my wife’s vehicle is parked.
The garage is too narrow to allow conventional doors on this storage.
Most things stored in totes or milk crates and using all of the ceiling height was my way to make this space work.
