garage slab insulation
jeff_gates
Olalla, WA
I'm getting ready to pour my attached garage attached.
This slab will not have radiant heating, also it will not be a work garage.
Should we install the 2 inch f250 pink insulation under the slab?
The garage will not be heated and only be used for parking the cars.
Out side of Seattle.
Thanks,
Jeff
wssix99
Chicago, IL
If you aren't going to heat it and aren't you going to put an insulated door on the garage, I can't imagine a reason to insulate the slab.
dallasjeannie
Depending on your future plans, I would consider the resale value. The best time to put anything under concrete is before it is poured (duh). 8 or 10 mil vapor barrier over #3 clear stone is the minimum before pouring, but adding the 2" XPS on top of the vapor barrier is a good idea that is not too expensive. But then only one step further, if you install 1/2" id barrier pex lines spaced 8" or 12" for radiant floor heat your floor will be ready for radiant heat should someone in the future decide to finish the job with a water heater of sorts. You can skip the heat source and controls yourself since that can be the expensive portion, but the resale consideration is a plus. Depending on the location and value of your property this plus could add 5-10% to the listing price.
lakeroadster
Central Colorado
If not heated and not a work area, you will benefit most from a good vapor barrier.
Define "Benefit"...
The American Concrete Institute’s (ACI) Committee 302 “Guide for Concrete Floor and Slab Construction” suggests that a vapor barrier may not be necessary where no drainage or soil problems exist and in arid regions where irrigation and heavy sprinkling are not done.
Strength.
Concrete placed over a sand bed was more than 30% stronger than concrete cast on the polyethylene.
ACI 302 indicates that placing concrete in direct contact with a vapor barrier increases slab curling.
Read the details here: http://www.stegoindustries.com/docs/Vapor Barriers Under Concrete Slabs.pdf
http://www.garagejournal.com/forum/showthread.php?t=326215
Jess
Vancouver Island, BC Canada
As already suggested, I'd go with a decent 10mil poly vapour barrier, at least 2" of XPS foam, pex pipe for future heating, rebar reinforcing and a decent concrete mix. Once the floor is poured, you can't go back and do any of this stuff. Lots of opinions and many are based on location and experience. Ask a decent concrete contractor that does work in your area.
matt_i
Personally, unless you are laser focused on radiant heat, or want it in the future as more funds become available, I think the XPS under the slab is a waste of money.
I would do rebar or welded wire mats. I would do a vapor barrier. I would do washed, crushed limestone same depth as concrete. I would compact the subgrade if disturbed. I would compact the limestone. I would use chairs or dobies and not hook the mesh up into place.
