Garage window installation height
plcguru
Finally gonna start the detached garage build. It will be 35x45 interior with 14ft ceiling. 2 10x12 garrge doors in front and 3 windows on one side. Primary use is auto restoration as a diy retired guy for fun not pro. What distance from floor should windows be installed? Is 42inches pretty typical? I'm guessing 48inches for all the electrical outlets?
Thanks
Jeff C
Durham, NC
How tall are the windows?
If you store any 4x8 sheet goods put your outlets at least 50” from the floor so they don’t get covered up.
MrFreeze
Seattle, WA
My shop has 13' ceilings, and I had the windows put in fairly high. I get a lot of light, but you can't see in from outside - at least, not on these walls. There is a lower window on the other end above my desk, and a normal one in the bathroom. The lower ones are just low enough I can reach the windows to open them. Thu higher ones (on the right on the pic) don't open, but are high enough I can put shelving etc. under them. Here's a pic from when I was just getting set up. This has worked out very well for me.
Good luck,
MrFreeze
P
plcguru
Windows are going to be 4ft tall... and good thinking on going 50in for outlets. I'm sure some plywood or whatever will follow me there. I hadn't considered that. Thanks
P
plcguru
Good luck,
MrFreeze
Nice setup and stangs! I'm afraid to do epoxy floors as I'd probably kill them in no time lol. I like the airline setup u have there. I have a 60 gal compressor with a 100ft retracting hose reel in my current space but thinking a piped system throughout might be better for the future garage. Yeah I still use air tools along with some battery ones... thanks
Codyboy
S.E. TEXAS
My new building the windows are sitting on top of the bottom girt. 4ft to bottom.
3040 windows.
I would do no less than 42".
The window in my other garage is set at around 36" and had to lower my workbench a little bit as ir is right in front of the window.
metschers
Billings, Missouri
My shop is about the same size as yours(36x48). I used transit windows all the around the top. They’re all non-opening. I chose these for light and security. About the only time I turn on the lights is at night. They allow tons of light to flood in. (10x10, 8x8, and 10x16 overhead doors).
P
plcguru
3040 windows.
Good point about a workbench... is that a 16ft height you got there? I'm thinking they'll look better from outside in my 14ft mounted higher up and probably less 'in the way' inside too. Thanks
mike93lx
Richmond, VA
High outlets are great over benches, but low works better with heavy extension cords.
I never quite got the concern for leaning plywood against outlets. How many sheet of plywood do you guys have in your shops and how spread out are they? I group materials.
For windows, I agree on lining tops up with doors for a 4' tall window
Jeff C
Durham, NC
My two car garage has a second floor with knee walls. From the outside the total wall height is about 13’6”. I had the window headers set at 9’ and the windows are 4’ tall. I think any lower would have looked too low from the outside. On the inside they are high enough to be out of the way for most things. Here’s a picture during construction.
Jeff C
Durham, NC
Have you seen all the hoarding threads we have? My problem is it varies which wall has the junk leaned up against it so I just planned for it to work with all of them. It’s worked well for me as I’ve rearranged the garage several times since moving in about ten years ago.
mike93lx
Richmond, VA
Most of us have too much **** in our shops, but have you seen plywood pricing?? Might as well bury gold in the backyard
P
plcguru
That does look nice from outside at 5ft. I guess I should go between 4 and 5ft to both be out of way on inside and look good from outside. Thanks
PCustoms
VT
With 14' ceilings I would consider moving the windows higher.
How far from the house is this?
Whatever you do, make sure it doesn't stand out too much from the other buildings
P
plcguru
35ft from house and yup same siding/shingles
OccupantRJ
Eastern North Carolina
Unlike most people it seems, I have no windows in the shop walls or doors due to some theft deterrent and mostly making maximum use of wall space. I also am a strong believer of out of sight, out of mind. Lights are on when I am in there anyway. The entire shop and storage barn are inside a fenced back yard with an alert dog who patrols all the way around the perimeter of the fence. He will bark, or both bark and raise the dead howling like a **** dog depending on what triggers him.
BillK
Beautiful Southern Maryland
Just wanted to add one more thought. If I was to ever build another detached garage it would have several skylights. It is amazing how much additional light they let in.
Also, I have always preferred a single much wider door over two smaller ones. I would rather be able to pull a vehicle in right to the center of the shop.
gregs
I have 12' eave heights and set my windows approximately 4' off the floor. It did 2 things, made the layout look better from the outside and allowed me to use 4x8 OSB inside without cutting as much.
CraigStu
Blacksburg, Va
I can see having high windows for security but I really like the window at my work bench being normal height. It looks out on the driveway/road/front wooded yard. I like seeing a car coming up the driveway and the squirrels etc.
no704
I’d put them as high as possible and use frames like skylights where you can kick out the bottom.
MovingAlong
And that's the challenge with most of these threads - how I work just might (just maybe) be different than you do.
As I get older, my back and knees are asking for the outlets to be raised a bit higher now... they have no concern for cord weight or any other practical matters, just want them raised. Chest high would be best (or so my back claims...). :unsure: :ROFLMAO::ROFLMAO:
mike93lx
Richmond, VA
Have you joined the corded vs cordless argument thread yet? :)
Bert_
NW Iowa
I like to be able to see out of a window.
Windows in the doors in my garage are high enough I have to stand up on my toes to really see out. Really wish they were lower
nicholsmf
TN
I didn't put any windows in my 30 x 46. I wanted the wall space. Still happy with my choice.
Wes Tex
My 30 x 40 shop has 14 foot walls and two rollup doors. I have seven 2x4 windows placed as high as as they could be mounted. I wanted to maximize my wall storage space and maximize security. The incoming light is almost like having skylights. I have never had a window broken in a hail storm, and they don't collect dirt like the skylights.
Codyboy
S.E. TEXAS
This. To me a window is useless if I can't see out if it. Even my man doors are half-lite. I want to be able to walk by and see out on all sides basically. And being the bottom girt was 4ft. Ta-da.
No brainer.
Yes OP my eaves are 16ft. Doesn't look bad at all to me from the outside. No different than a 2 story house with windows at the lower level.
The only thing I would change would instead of 3x4s maybe do 3x5s or 4x5s. But I was way over budget.
I will eventually have a loft on that left corner.
I may add a window up above for it.
But regardless, not concerned with looks. Those windows face the woods.
nadogail
Coronado, CA
I used to patronize a bicycle shop that was broken into through the skylights, they were soon re-enforced to make entries more difficult.
racecougar
Missouri
When I set my window height, I measured my work benches, then set the height of the window sill to be 3-4" above that. I agree with some of the posters above, seeing out of the windows is nice. That said, I'm out in the woods where the views are great and I'm not worried about crime.
dcg9381
Austin, TX
Personally, for a shop/garage, I want the windows to be above my head. They let in light, but keep nosy neighbors from seeing what is inside and make it a little more difficult for someone to break a window and ingress the garage.
Around here, they keep the nosy tax man out too. Soon as they figure out your garage has HVAC/bathroom/kitchen, some places tax it like residential...
borgdog
Spokane, WA
I also have mine up high, but for me it was more about distractions. When I'm working with power tools I don't want to see people or whatever going by the window that might instinctively cause me to glance away from what I'm doing. I like my appendages right where they are attached.
Zugec
42" is pretty common because it keeps benches and toolboxes from blocking them and still gives light. Outlets at 48" would be a smart in a shop I guess because it would be way easier to reach over benches and you don't have cords dragging on the floor. I've heard some guys even go a bit higher, but 48" is a solid choice.
