tom fleming
Hi guys, I just picked up a working Gardner Denver ADD-1011 compressor in pretty good working shape. I have been trying to find what the CFM rating is on it, and so far, have come up empty.
The primary bore is 4.5" and the secondary bore is 2.25". Stroke is 3.5", and is rated at 200 PSI at 870 RPM's with 5 HP motor.
I know there should a specs sheet of what CFM this puppy will put out, but I haven't found anything yet on the net. Anyone know what this will produce from a CFM perspective? I would like to run a small sand blaster and be the primary air for the shop.
I would guess this is a decent unit, and Gardner Denver still produces rebuild kits for it, with rings, seals, valves, etc. Anyone know anything about these?
No wonder it takes so long to fill. Although I did find the piston rings to be mostly worn out and a broken valve spring in the head, so keeping my fingers crossed.
