Gas flow problem with Miller 211
Debriefer
My Miller 211 isn't flowing gas properly. As soon as I power up the welder (no trigger), I can hear gas flowing out the nozzle, but very slowly, nowhere near what it should be when the trigger is squeezed. Squeezing the trigger has no effect, it just flows that little bit still.
I took the side off of the welder, and checked voltage at the gas solenoid. With the welder switched on, it's 120V AC right away, and again, the voltage doesn't change when I squeeze the trigger.
I have verified that the trigger is signalling the PCB properly with a multimeter.
Any ideas? It's just over 3 years old.
BigMike782
Is the gas solenoid opening and closing(can you hear it click)
Have you had the gun out of the wire drive(to change wire) and the gun is not fully seated?
What flow rate is your regulator set at(cubic feet per hour)?
BD1
north side
Start with the tank and regulator. Before attaching regulator crack valve on tank to blast any debris, spider webs, bug, whatever may have moved in while sitting . Remove hose connection at regulator and check for flow and then reconnect and disconnect hose at machine. Spider webs and restrict flow.
D
Debriefer
Thanks, but why is it flowing out the gun as soon as I power the welder on?
great white tj
Ocala Fl.
There are two wires that run from one of the boards in the welder that run to the back where the gas port is, one of the two is bad ( board or your gas solenoid). I would call Miller Monday and they will fix you right up.
Slick111
Everett Wa
My Miller 180 did the same thing turned out to be the gas regulator went bad you could hear and feel the gas out the nozzle when testing it out but 2 -3 seconds into a weld it wold drop by 75 %
D
Debriefer
Got the call yesterday. The board had a stuck relay, so they replaced the board.
The welder is a little over 3 months out of warranty, but they fixed it for free. I just need to pay a small transportation fee of about $40.
Picking it up next week. Can't wait.
Thanks for all the input.
sk farmer
nd
good to hear that miller steps up with tech support and parts. i hope that the new 211's are as good as the old versions. the 211 is the standard in compact welders and the bare minimum to get. i have never been sorry with mine.
sberry
Brethren, Michigan
There are a lot of companies that could learn a lot from those guys. They have the absolute fastest best easiest way to solve problems ever invented.
Ms6peters
Nor Cal
I had an ah-ha moment on my 211; the hose assembly wasn't fully seated in the unit. Close visually, but not fully seated.
