GasBoy 72 pump
Sumboodie
AK
Have an older GasBoy 72 pump on a 1000 gallon diesel tank.
I put it in service a few weeks ago, hadn't been used in probably 10+ years and it fired up without issue aside from a leak leaking between the pump and motor that was getting worse with use.
Think it was just 2 hardened orings, but I bought a full service kit for it as I wasn't sure what it would need and didn't want to tear it apart and wait several weeks if I needed parts.
Kit was new orings, gaskets, rotor, vanes, check valve, etc.
Put it in this morning and can't get the pump to pump. (Lovely)
Have spent easily 4+ hrs screwing with it. Tried priming it with engine oil, reviewed the IPL, pulled away to make sure I didn't goof anything put old parts back, even bypassed parts.
I'm at a loss. Don't have time to be dealing with this, just need it to work. A new one is about $1800, so not happening.
S
Sumboodie
AK
Got it working. Put together a garden hose to pipe adapter and stuck my M18 pump on it.
No idea what its deal was, but working fine now. They aren't supposed to need priming, tank about 1/3 full so only ~2. 5ft of lift too so dunno.
B_Bimmer
Eastern Iowa
I would have suggested dipping vane parts in motor oil. They aren't supposed to need priming but all dry can still make it tough after a rebuild.
S
Sumboodie
AK
I filled the whole pump several times with oil.
Thought it was fixed but had to reprime a few days ago. Makes no sense, has 2 check valves
