Gasket material assortment
NBN
SE Tejas
Minus the obligatory cereal boxes and beer case cardboard gaskets, what is your preferred assortment of gasket material for use on your cars? I know of the small felpro packs, but what do you seem to use more of?
L5wolvesf
Northern AZ
Kind of depends on what vehicles you have. I would have some cork along with the "cardboard" type. I would avoid the rolls.
N
NBN
SE Tejas
I've got a little of everything. Newest old car is 1973. Oldest old car is 1929, but I've been known to work on older.
nadogail
Coronado, CA
You need a good industrial hardware store, they will have, or can get, everything you need. If they can't get it; you are probably better off without it.
N
NBN
SE Tejas
Mcmaster Carr sells various types of gasket material in small sheets.
Yep, they do. My question is what is the most common, or preferred material? I could spend a whole day going through choosing all of their offerings as well as a good chunk of my bank account.
BillK
Beautiful Southern Maryland
I cannot remember the last time I had to make a gasket ???? Either for my own vehicles of which the newest is 1999 or for stuff at work which goes from the 40's to 2021. I have always been able to find what I need. What on earth are you working on that requires you to make a gasket ??
N
NBN
SE Tejas
Pre war cars mainly. Try finding a gasket for a transmission with a freewheeling unit for anything other than Packard.
BillK
Thats fa
Thats fair enough :) I am only working on engines and simply do not have a problem. That being said, I have had some Fel Pro in the past and never had an issue. As far as material I would want to replicate what was there from the factory. If it was cork originally that is what I would replace it with etc.
Copymutt
Colorado
More than once I’ve used aluminum flashing to make head gaskets for small engines. Usually increases the compression over stock.
Syberia
Perris, CA
Silicone. The one time I've had to make one, I cut up a silicone baking mat from Wal-Mart. It was for an old log splitter from the 80s? Trying to find one online was fruitless.
  • Like
Reactions: NBN
Engineer61
Colorado
Looking at McMaster-Carr, I would get some of the oil-resistant Aramid/Buna-N for most gaskets, some of the oil-resistant Cork/Buna-N to replace any cork gaskets, some water-resistant Aramid/SBR for water pump gaskets and some of the Graphite High-Temp High-Pressure (850 degree) material for exhaust gaskets. That selection should handle everything in the drive line except a head gasket. I prefer 0.040" thick dead soft copper sheet for head gaskets.
Or you can just get some tubes of RTV and hi-temp RTV and glue everything together.
N
NBN
SE Tejas
No RTV gaskets for me. Thank you for the info.
BlakeTheCarGuy
Roanoke Virginia
Cork. My dad has an old roll of it around here somewhere. If you are fixing older stuff it’s fine I would not use it on newer stuff though. RTV is next because really these days there aren’t many options. You can’t even find rolls of cork in the stores anymore to make gaskets. When I do make a cork gasket I always coat it with Indian Head gasket stuff that stuff will seal it up very well. :thumbup::thumbup:
  • Like
Reactions: NBN
