Very nice. Thanks. Hobart states at full power (190 amps) the welder is at 5.8kw's. Hmmmm. My generator is 5.5 kw's.
Yes, but the rated output is 3.8kw. The duty cycle at 190a will be much smaller than the 30% it's rated for - ie, you'll probably only see 15% duty cycle. If you really are welding 190a with this on a regular basis, this is where the "peak power" of the generator comes in to play - it can handle that load for a similar smaller duty cycle just as the welder can.
The 190 gives 190 amps at ~19 volts...that gets you 3.8kw. A welder is only so efficient... but 5.8kw vs 3.8kw would get you a 65% efficiency where I think it's much closer to 75%. Again, these are just peak ratings.
