generac generator question
drydoc
I purchased a used 15 kw generac generator, model 4390-0 which uses ng pressure of 11-15 inches water pressure. newer unit of 4390-03 uses 5-7 inches like every house has in the country of course. the question is can I convert this unit by using the newer gas regulator and mixing box of the 4390-03 as the engine and everything else is the exact same?
Norcal
It is inches water column, not water pressure, 7" water column translates to about 1/4 pound of pressure. As to substituting regulators I don't know.
macdabs
Should be a simple change under the air filter assembly . Small lever similar to a choke on small air cooled engine. Some of the earlier units get a different jet on the regulator assembly .
D
drydoc
Thanks for the tips!!!
the unit runs on the same pressure for ng as lp source
no lever to switch it
since the remaining parts are identical i am going to try changing the fuel regulator and the mixing box and see if it starts easier
ihateminimumwage
There will be a fuel lever if it's an Evolution controller, Nexus controlled will be under the air filter cover. The Generac regulator in the unit is a demand regulator, the IWC will come from the regulator feeding to it.
