Generator Power....Out Building
slime
I have an out building with no power. I was thinking of putting in a service panel with ciruit breakers and having a circuit for ceiling lights and a circuit for a few plugs. Again, this building is not hooked into any electrical power grid.
I have a Generac GP5500 generator (120/240v). The frame is grounded to the ground terminals of the AC outlets on the generator. Can I just hook this up to the panel, using appropriate size wire (2 hots, neutral, and ground, or do I need a separate ground rod? There would be no transfer switch.
theoldwizard1
SE MI
I would install the ground rod and then disconnect the ground from the frame of the generator.
Bond ground and neutral in the load center in the building.
S
slime
wizard....why would you disconnect the ground from the frame of the generator? It is not hooked up to any electrical grid.
wyliesdiesels
Modesto, CA
I was gonna say the same thing. The neutral and ground will be bonded in the panel since its a main panel....
