Yes on both. 240v inverter. But it only has 1kw of surge capacityWith a soft start I bet your 5500w unit will work. Does it have a 240v output? Is it an inverter unit?
Everyone needs to be aware that there is more than one kind of "soft starter" !I would get a soft start for sure, not only does it make it easier on the generator but it extends the life of the compressor too
I would go for a minimum of a 6000w generator there with a soft start just to give some room for other appliances and the inrush of the AC.
My electric bill won't help at all. I have three a/c units that often all run at the same time, but I have no need to ever do that in a power outage. 1 zone is plentyYou have a minimum amps of 19.3 and a maximum breaker of 25, so 5757 Watts. I would consider a 6kw generator marginal at best. Personally, I would look at my electric bill for my highest KW peak and consider that the generator size I would need. YMMV
This is what I do, using the same Champion inverter generator as HamAndEggs has. Mainly because the 5ton AC is nearly 30 years old and I don’t want to put it under undue stress trying to kick over on generator power (regardless of generator size).May consider having a window unit or two in storage and just run those via genny during the power outage?
Septic pump is 120v, IIRC. It's just pumping water up a foot and then to the drain field, so it shouldn't be anything substantial.Ah, I missed that yours is 2.5ton. I’d invest in a soft start and take it for a spin! What does the septic pump draw? 120 or 240? Can it and the fridges be shut off while the air is running?
I am on board with that! Now you get to weigh the balance between generator size, convenience, and fuel consumption.I'd do what I have to, but turning stuff like fridges on and off if not where I want to be
Unfortunately, no. That would be my first move if it was possible.Does your current generator have the functionality to be run with a parallel kit? Then you could just get a second one day and have double the power
Best solution, especially if you don't want to invest in a whole house solution.May consider having a window unit or two in storage and just run those via genny during the power outage?
ThanksHere is a thread on my Softstarts for my 2.5 ton AC
HYPER SURESTART - Soft Start
Well, I just Purchased a HYPER SureStart to try to get my 2.5ton AC unit to start using my 7000/12000watt Generator. I figured I would show the Kit and what it looks like. I will show the hook-up and running and let everyone know the results. I am hopeing for a 40% decrease in Power...www.garagejournal.com
I got 2 these off EBAY been working good but only tested them...I have not run my Generator for long peiods off them yet.
That being said they are running every day off the local powergrid..at least from the day I installed them.
4 ton single stage, or a 4 ton inverter air conditioner. Big difference between the two on starting load.Its worth noting my 8750 starting watt generator is just 7000w running. Runs my 4 ton AC/Air handler, 10a (120v) of computer's, lights, fridge etc with no problem
Its a little more complicated than that. You need a clamp meter that has circuitry for reading in-rush current. Not all clamp meters have this. Fluke has several models that do. Theres an in-rush current button on themAre clamp on amp meters sensitive / reactive enough to actually get a good reading on in-rush current? If so, I think that'd take out a lot of guess work.
I'm shocked at how little power our house pulls 2 AC (2 ton, 3 ton) and it's not a small house. I installed a 20KW generator and I've only seen the house draw 10KW once. But then again, I have no idea what the demands are for inrush current.
I'd love to get one, but $350 plus is a tough pill to swallow for such a specialized toolIts a little more complicated than that. You need a clamp meter that has circuitry for reading in-rush current. Not all clamp meters have this. Fluke has several models that do. Theres an in-rush current button on them
A Klein CL390 will read max amps for your startup just fine. Less than $100.You've got a nominal value of 11.8 + 0.9 Amps, and let's say 220 V that comes out of the generator.
A motor is somewhere around 80% efficiency, so 13 x 220 / 0.8 = 3750 W.
Without a soft start, I'd say you'll need around double of that to be comfortable.
With a good soft start, this drops to 20 - 25% additional.
Don't forget that "crude" gen sets can mess up a lot of the electronics in household devices. Those will probably be fine for that A/C. You can throw almost anything at electric motors.
An invertor would be ideal to feed any "smart" devices (that need a stabilized sinusoidal volt/current power supply like hifi, most electronics, ...
actually even though there is a min max option, doesnt mean it will read in-rush correctly. Fluke did research on this and thus came out w/ meters that specifically have circuitry that reads in-rush current, with a button to activate it. the meters also have the min max feature...A Klein CL390 will read max amps for your startup just fine. Less than $100.
Concur ! Very difficult to measure ACCURATELY !actually even though there is a min max option, doesnt mean it will read in-rush correctly. Fluke did research on this and thus came out w/ meters that specifically have circuitry that reads in-rush current, with a button to activate it. the meters also have the min max feature...
