Greetings to you all,
I have a huge problem with my lift.
The machine is: Genie GS 4390RT from 2001
Motor: Deutz
History: The machine had a few tweeks with switches which I replaced and It was working fine until one of my colleagues while expanding the platform ripped the joystick cable.
Present: The cable was reconnected but the diagnose display turn on while on platform controls but it's of when you switch it to ground control and the joystick has no lights on it. On platform controls diagnose display shows 02 error. After that I opened the joystick and found that the wires that come from the joystick cable wiring are torn from the electric board. I took the ******** and connected the directly but still no change. I tested with the OHM meter every connection on the board and It's ok, also on the end of the cable everything ok.
Now i need help what could it be. It's too expensive to buy a joystick and figure out it's not the joystick. If you can please help.
Motor: Deutz
