In Lumps thread on an old two wire metal cased drill ( http://www.garagejournal.com/forum/showthread.php?t=90709 ) the question came up about adding a three wire grounding cordset. I understand that if the ground wire is terminated on the metal case it will ground the case and add the safety of the modern grounding system. I would think that if you have proper GFCI protected recepticals in the garage as required today that adding the ground wire to an old piece of equipment is unnecessary as the GFCI would detect a short in the tool. What say you trained and educated people?
lg
no neat sig line
lg
no neat sig line
