gfci outlet
scotty95
mid michigan
Have an enclosed cargo trailer. Ready to wire 2 flourescent lights inside. Being I don't have a fuse box, I have power coming into trailer with a waterproof 15a input, can I use a gfci receptacle to act as a fuse for the inside power supply? I'll run the power from the gfci to light switch to power the lights. Is this possible? Thanks for all the input, Paul
AntonLargiader
Charlottesville, VA
GFCI does not act like a fuse. Does not trip on overcurrent.
Personally I would skip it*, and rely on the overcurrent protection of whatever is powering it. Run 12 AWG cables so they are protected even when plugged into a 20A circuit. Basically the trailer is just a light fixture at that point. Possibly with a receptacle (which some light fixtures have).
*EDIT: I'd skip the overcurrent protection. Running the power through a GFCI receptacle is a fine idea for ground fault safety.
wyliesdiesels
Modesto, CA
Thats a popular misconception.
Receptacle GFCIs DO NOT provide any sort of overcurrent protection.
However, i WOULD put one in the race trailer to protect against electric shocks.
sberry
Brethren, Michigan
Run number 12 cord, the reason is you can use multiple outlets without further over current protection. If you use 14 it really needs a fuse like a power strip has.
Same thing Anton said really.
mikegt4
sw ohio
When I converted my van to a class B camper I used a 2 space breaker box. They are small, cheap and available at the big box stores.
Saw this trailer the other day with a 4 space box on the wall and a door in the floor to drop the RV style cable out. Other trailers had a RV electrical inlet on the outside of the trailer.
tfi racing
Cedar,BC
120V fluorescent fixtures in a cargo trailer are a dumb idea,just way too many LED options out there right now.
sberry
Brethren, Michigan
If you are going to 30A service then you do need breakers, if its 120vg and has a 15 end on it to plug in to a common circuit you don't.
S
scotty95
mid michigan
Not putting 30a in this. Keeping 110. Can you just replace the flourescent tubes with LED? Or is the fixtures different for led. Thanks again.
Dick in Wisconsin
Shawano, Wisconsin
110 can be 30a. 30a can be 100.
I would start out with LED fixtures in a trailer and NOT screw around with fluorescent fixture and then later try to adapt LED to those legacy fixtures.
