ducatithunder
I know its been beat to death but after searching I am still torn between the two.
I have my 1300sqft garage enclosed at this point. Before I start to finish out the inside and move things in I would like to seal the floor. The concrete is 4500 psi that was power troweled to a polished/burnished finish. The contractor sealed the finished floor with a chemical cure top sealer for a curing aid.
At this point the slab was exposed to UV and weather for about 3 months until I was able to get it enclosed. The surface does not repel water anymore so I think the chem seal is gone.
So, now I and trying to decide on which route to go. The garage will be used for automotive projects and welding. Where the welding is going to take place I will most likely have another flooring covering the concrete.
I do like the look of the wet polished look of the HD40 but also like the oil resistance of the 8510. Both require a densifier, so no savings there. What prep will need to be done to remove this chem cure? Im concern if I have to etch the concrete it will distort the finish.look I have currently. Any other prep other then clean, wash, and dry. From what I have read the 8510 just seals and wont give the floor a wet look, correct? I am located in MD so the weather is not going to be back in the 50's for another 3-4 months if temperature of the slab is an issue.
Any advise would be appreciated. Thanks in advance.
