Ghostsheild 4500/8510 DIY application imminent
robb1887
I've been trying to find the most recommended success stories using Ghostshield products to coat my floor before final move in. I'm having to apply in two sections for my 28x40, using the cut relief as my divider (2/3 1/3 split) as I unfortunately have some stuff moved into the space already. I pressure washed yesterday to get the large paint/junk from the last two years off.
I'm looking to confirm what I've read here or there that for my smooth trowel finished floor:
Degreaser
Pressure wash
Dry
Single flood coat of 4500 in a 4:1 ratio
7 day cure time minimum
Double flood coat (wet on wet) of 8510 as mixed
24hr minimum cure
I have the following materials:
Solvent rated hand pump sprayer
Microfiber rollers for puddling if present
spike shoe adapters for the wet on wet application of 8510
madison069
Monroeville, PA
My concrete was new so I didn’t degrease, old concrete will most likely need it.
Give it a week to cure after 8510 and I used a garden sprayer to apply both 4500 and 8150. It was slow to dry after applying the second coat of 8510.
I’m happy with the results, easy to clean up if I get to it quickly and low dust. My bunker isn’t treated and I can tell how dusty it is compared to the treated concrete.
R
robb1887
I've done some car/mower maintenance and feel like I should degrease to be safe, I only get one shot.
Dusting is a huge concern currently still so I'm glad to hear that helped. I will be doing a lot of mecahnical car work and fabrication so I figure the sealer is the best application for me since epoxy's/coatings can burn from sparks/embers
Shea
California
I would double-check the application methods for 8510. I believe only one flood coat should be applied past the saturation point at an approximate rate of 300 sf. per gallon.
R
robb1887
This is directly from the website, but I'll double check the labeling when it arrives as well. I only have the 4500 in hand currently.
"Apply with a solvent-resistant roller, brush or low-pressure, non- atomizing sprayer. Apply to saturation letting the first coat penetrate for 5-10 minutes. If applying a second coat, reapply in the same saturating manner wet-on-wet (applying the second coat before the first coat dries). Less material will be needed for the second coat. Roll or broom out any puddles until the sealer penetrates the substrate. If it starts to rain, stop treatment and cover the impregnated areas."
RescueK9
Anyone have pictures of what it looks like a few weeks out? Does it have a shine at all?
y'sguy
Tulsa, Oklahoma
I really wish I had done this.I cant' figure out how to successfully move stuff around in the space over a week or so period of time. I certainly can't keep one of the cars outside for this time!.
Maybe I could do it halves? Any ideas?
madison069
Monroeville, PA
You can check out my experience here starting at post 201 for getting my floor ready for sealing. I did wet on wet application of 8510.
Photos of the end results are in the thread also.
R
robb1887
I really wish I would have done it way earlier in my shop build to prevent as much prep requirements.
I'm using a saw cut in my floor I will mask off to separate a 2/3 & 1/3 application with stacking all my stuff up in that 1/3 area for the majority application, then moving it back over to get the last 1/3. Definitely stinks to draw it our for 28 days to full cure time if no gaps for heavy stuff (lathes and mill for my shop).
R
robb1887
You mentioned in your build thread only using 4.5 gallons in your 32x32 space? Based on a 300sqft application coverage reccomended and then "less needed" for the wet coat should be somehwere in the 5-6 range no?
madison069
Monroeville, PA
You are correct, by the math it should have been 5-6 gallons for a proper 2 full coat of 8510. From talking to others who has applied 8510 they experienced a white chalky substance showing up in the heavy pooled area they had. So, to avoid that I did my best to keep it from pooling up and if I applied the full 5-6 gallons on the concrete it would have not dried clearly. From what I gather, some concrete will absorb that stuff up like a sponge but mine was fresh power trowelled concrete and so it didn't absorb as easily as other folks has shown.
So, if your concrete will absorb the solution easily, then I would do my best to get the full amount on it. But if it doesn't absorb easily, then I would lower the amount to prevent issues. Every concrete slab will be different and so far, mine has been easy to keep it clean. If I leave oil on the concrete, it does leave a very very light stain that eventually disappear over time, but I know from experience that an untreated floor would still have a very dark stain there. Water will bead up and leave no trace when I wipe it up. I kept walking on water in the garage and kept wondering where it was because I couldn't see it due to the concrete didn't change color! I'm happy with it!
R
robb1887
Yea, I believe mine was manually finished but don't know for sure. I didn't catch them doing the finish work on the slab 2 years ago and it wasn't that detailed in the contract info.
I do know a neighbor that had the same crew build recently. I will see if he caught what they used to finish the slab. I'm not sure if any of the concrete experts in here could say one way or another from any specific photos. A google AI evaluation suggests it is power troweled, based on some of the swirl looking marks in the middle slap I suppose.
Tuesday I manually removed some paint splatter the first pressure wash didnt take up and degreased with a final pressure wash and some more stuff movement to get the two slabs fully prepped/clear and drying for Friday night application of 4500.
madison069
Monroeville, PA
Any updates?
Looking at that photo, it looks very smooth and could have been power trowelled then joints were saw cut.
R
robb1887
Doing a little more google research I made a personal determination that it was power troweled.
I applied the 4500 (single coat) just before our week vacation which was perfect for a cure time. The 8510 (wet on wet, 2 coats) was applied as soon as we got back to allow it to cure over the week before moving all the equipment over from bay 1 to repeat the process again.
The 4500 (1:1 dilution) was sprayed on and subsequently rolled with the 3/8 microfiber roller to even everything out.
The 8510 was sprayed on, then wet coated shortly after, then rolled over in both directions. The finish had a slight sheen a few hours later but I'm hoping its going to dull back out.
I'm not sure if because I am power troweled AND conditioned that the absorption rate is so slow, but the "minute or two" on the label was not seen for my application of either product. It did seem to soak/evaporate better at the edges that are likely significantly warmer due to heat soak than the middle of the slab. I also did zero of the testing suggested as I am up against a deadline for move in. Ambient temps were 74°F-ish during application and a dehum running at 55%.
The sweep prior to the 8510 already showed significantly less dusting which was my biggest dissatisfaction so far with my pad.
Friday night/Saturday will move all the equipment for washing/degreasing bay 1 with a target to apply the 4500 on Sunday the 12th, and 8510 the night of the 18th.
madison069
Monroeville, PA
The floor does have a little shine to it, but not too bad. If it’s going to be a working garage it will dull over time from what I’m seeing.
R
robb1887
The photo with the floor and bucket is still with it wet. It dulled a good bit but the hard trowel spots do have some sheen left now 24+ hours later.
I am using significantly less product as suggested with the power trowel finish by the label coverage as these two bays at ~ 746sqft used ~1.5 gallon of diluted 4500 and just shy of 2 gallons of 8510.
