Gillette 4250W Alternator power head
anythingyoucanimagine
New England
Are they any good? No idea if it works, it's just the power head without anything attached to it. I understand the difference between a generator and an alternator. It was free and I took it thinking I could attach a bigger motor to several power heads but this thing is going to need a full rebuild.
Wondering if I should make the local scrap guy happy tonight or save it. Thanks.
A
New England
Sticker says 4250 cont. watts, 120/240, 35/17.5a, 60hz, 55c temp rise. It was free, it is in my garage. If it works and is reliable I was going to give it to a friend so he can use it in his boat as belt drive to run a small ice machine and AC unit.
American Locomotive
Rhode Island
Is it a standalone generator head with a standard shaft sticking out? Most generator heads are designed to bolt directly to a tapered shaft on an engine.
If it has a standard shaft you could put a pulley on, there's no reason you couldn't test it. You just need to verify if it's a 2 pole (3600 RPM) or 4 pole (1800 RPM) head. To generator proper AC power, it must be turned at the correct RPM.
TractorJeff
Elkhorn, WI
My brother had one years ago that sounds similar?
He made a mount to hang it on the front of his Garden tractor.
He ran a walk-in cooler with it when it had meat hanging in it.
A
New England
It's made to mate up with an engine so there's no shaft on it. I guess I'll hang onto it until the Southbend is together so I can practice cutting tapers.
Greyhorse
Canton, TX
I have one that sounds identical to that on an 8hp B&S engine along with the framework around it. Works fine when I’ve needed it.
A
New England
Thanks. That's actually a huge help. I'm still going to have to learn how to turn tapers (eventually) on a lathe but short-term I'm pretty sure I saw the B&S motor for that gen power head when I picked it up. Thanks.
