Go 30 wide or 40 Wide?
bkdawg61
South Jersey NJ
Looking at having a 30x40x12 built. Originally planned on going 30 wide and 40 deep but looking for opinions. Should I go 40 wide and 30 deep? Also contemplating having 2-10x10 doors or just 1-20x10 door. Any thoughts?
matt_i
Personally I would go 30 wide. Spanning 40ft is certainly possible but the trusses are going to get more expensive and harder to set due to their weight. But, either is definitely possible. Many 40x60 buildings are out there doing just fine.
jd_1138
NE Ohio
The doors are usually parallel with the trusses? But I guess you could do doors that are perpendicular to the trusses and thus have a 40' wide by 30' deep garage. Though a lot of rain will fall down in front of the doors.
ishiboo
Oshkosh, WI
What are you doing with it? What do you plan on fitting in it? That would completely determine it for me.
I had a 30w, 40d and it was perfect for me... 29' boat on a trailer just fit with about 1.5' to spare. 30 wide is room for 2 cars plus a ton of room around them.
My new garage only (not shop/boat storage/etc.) is going to be about 40w x 30d or 32d... will have 3 cars across the width.
RayBob58
St. Louis, MO
I put a single 8'x12' wide door on the 28' end of my 28'x36'. It will be used as more of a workshop than a garage. The single bay in front of the door will always be empty. I hope.
Bib Overalls
Jonesboro, Arkansas
I have a 30' x 40' shop building and it is perfect for me. When I was researching the build I was told more than once that 32' wide was the sweet point. Any wider and the the price of the trusses accelerate. At that point it was better to add length rather than width.
A 30' x 40' works out to 1,200 sg ft. A 40' x 40' is 1,600 sq ft. a 30' x 50' is 1,500 sq ft. I would price both ways. You may be surprised at how much the additional 100 sq ft will cost. And then again I could be all wet.
ItsNemo
Canada
30 wide, 40 deep...you'll only be able to fit one vehicle deep with 30 depth. 40 deep means you can tandem park.
Fredro Starr
Atlanta Metro Area
I elected to go 40 W x 30 D.
I agree with the quote above. It is the difference between a 3 or 4 car. My lot dictated my size and since I wanted living space above 40W better suited my needs.
I agree with the other posters that form should follow function.
indebt
KY
I just built a 30x32 with one 18' door. I think a 20' cost goes way up. Also I had 2 doors at my old garage and now having one, I much prefer just one. Pull anything and everything in.
stngfever
West Michigan
It all comes down to personal preference and function of the space.
Mine is 40 w x 32 deep with 12 foot walls. I did 3 - 9x8 doors.
Mine is setup such that it will never have more then 3 cars (one bay eventually will have a 4 post lift for double parking, etc... Center bay has 2 post lift, last bay for general detail work or other misc.
I have a friend that did his 30 wide x 40 deep with one wide door. Open floor plan with no lift as he has 10 foot walls (now wishes he did 12 and installed a lift). With this configuration, he can put 3 cars width across back wall and 2 more cars by door. Allowing work to be done on 1 vehicle at a time but cramped.
James-W
Southeastern Wisconsin
I never heard someone complain that they built their garage to big. :D
I haven't either, but I did know a guy who bought a house with a 4 car garage and he put up a wall across half of the garage. He just parked his cars in one side and used the other side as a workshop. I know that isn't exactly complaining his garage was too big, but it did cut his garage work space in half.
Blazinzuk
Afton Wy
Mine is 30 deep 40 wide. I really want to add some length to it. The 40 wide is awesome but one of my projects is a crew cab long bed and I have picked up building utility racks for our local power company those are usually crew cabs with 9 or 10 ft utility beds on them. So I need more depth but that is specific to my situation
Catadj78
Alabama
I went 40x40x10.5 because of my lot. 2 10x8 doors on the gable end and 1 8x8 on the right side. I wish I had went wider another 10' but 50' trusses cost.
bkdawg61
South Jersey NJ
I think the 30 wide 40 deep would look nicer on my lot but want it to function for what I want to do. As of right now my F150 and my wife's suv will be the only 2 vehicles parked in there. I would like to put a 2 post lift in down the road. Don't have plans on a project car right now maybe a 22-23ft boat at some point.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
A lot of which way to build it depends on your property. Can you do a Google Earth shot and then draw the building in both ways to try and determine which best suits your needs? I built my addition at 28' wide and 36' deep. I had to do this because of my septic system, and I also had to consider the aesthetics of adding onto my existing garage. I would have been happy with 36' wide though but my leach bed would have been encroached on.
I think you would be happier with a 40' wide garage vs. a 30' wide. I would go with the (2) 10' wide doors also. In the winter, pulling in and out, if you are heating the garage, you won't be dumping all the heat out like you would with a 20' wide door. Building the garage at 30' deep, you have room for a fullsize vehicle with a workbench in the front. My main garage is 28' deep, and I can pull my Dodge Ram 4door 4wd in and still have room to walk around it. But I'm going on what would suit my needs. You may very well want a 40' deep garage. At 40' deep you can park two vehicles in tandem. That would let you easily park four vehicles in your garage.
Are you planning on putting a lift in eventually? If so, then you might want the 40' deep as the side with a lift, you will normally park one vehicle on that side, and you can get two in tandem on the other side, giving yourself room for three cars and a bench either on the side, or in the front of the garage.
lakeroadster
Central Colorado
Those awesome new things called "rain gutters" make this a non issue :thumbup:
ishiboo
Oshkosh, WI
If the trusses are perpendicular to the garage doors as he is talking about, that would put them on the gable end where gutters are not installed. Being that much of the roof is substantially higher than the doors, the same overhang typically gives you less protection from rain.
If that's a substantial issue (for most people I would think its not a big deal) you can install a roof overhang over the doors. I had trouble finding a relevant photo, but basically like this but you would go out the same distance as your overhang on the sides, and no posts are needed: (It's actually a lean-to)
lakeroadster
Central Colorado
:headscrat
Doors located perpendicular to the trusses would indeed put them on the side, not the gable.
Doors located parallel to the trusses puts them at the gable end.
finn
The UP, God's country
My garage is 32'x54' with three doors in the long (eave) side.
If I were to build again I would avoid that configuration if at all possible because of the snow shedding off the roof in front of the garage doors.
The snow compacts when the roof sheds, making it difficult to remove with the truck, and impossible with the snowblower.
My shop has a gable entry door and doesn't have that problem.
lakeroadster
Central Colorado
Upper Peninsula.. That's gotta be rough.
Do you have snow trim on your roof?
I have it on my barn here in the Rocky Mountains.... snow shedding is minimal and not an issue.... but the roof has to be designed to handle the added weight of the snow.
Dormers over the doors would also help to deflect the snow to areas that are more advantageous.
bkdawg61
South Jersey NJ
Is it possible to get variance and go 40 x 40.
I already had to get a variance for the 1200. They limit you to 600 sqft or less without a variance.
I have been told about the snow issue when the doors are placed on the eave side. That was one of the reasons to I was going to go with the doors on the gable end.
Thanks for all the input this forum is great and easy to spend hours looking at other builds and seeing the input from people.
fabjunkie
Magnolia, TX
On my last shop I did 30w, 40d with two 12x10 doors on the gable end. I regretted it immediately. Once you take 4' away from either side for workbench, toolbox, etc, it gets cramped width wise. Also take 4' off the back wall and you're not fitting anything tandem and working on it.
Granted the truck is ~21' long, the car is 16.5' and they barely fit. This was before finishing the walls and having stuff against it.
This time around I'm 36'd x 50'w. A single 18x10 door on eave side butted against the center of the wall (next to the truck0 and a 10x8 on the opposite gable end, again butted against the center of the wall. I'm laying it out with two bays perpendicular to the 18' door (far end in this pic) leaving the space behind the door open. It's still in the framing stage, but you can kind of tell the layout here. The 10x8 door will be on the far wall, right of center.
bkdawg61
South Jersey NJ
Finally found the time to show where i plan on putting the garage. I'm worried that if I end up going 40 wide it won't look right with the house. What's everyones thoughts?
btdobie
Southern Minnesota
My Grandpa did the same thing to his shop so he would only have to heat half of it to work in and could store stuff in the unheated half.
TK-421
Pflugerville, TX
Go as big as you possibly can, too many people complain their shop is too small, how many complain their shop is too big?
marksland
Central Mass
I went with a 30 x 40 by 12 foot ceiling in the fron thalf of the bay and 18 foot peak in the rear half. I put one door on the gable end with a small roof over it for the elements and a secondary overhead door on the eaves side to allow access for smaller cars/toys/equipment. You can see photos in my signature line.
I think it comes down to a matter of personal preference and the intended use of the space.
spotco2
NW Georgia
I've got a 30x30 with 2 10' doors on the side that are evenly spaced.
Someone else mentioned putting shelves and benches on the sides eats up that extra room, and it does more than you would think.
I could have gone 40 wide and should have, but didn't......yet.
