Going rate for professionally applied epoxy?
JoeGarageHand
Called a local business who does epoxy and other types of concrete staining, etc. to get a bid for my 1400 sq ft garage. They quoted me $3.60/sq ft for gray epoxy ("Rock-Tred") with UV clear coat (no flakes). Looks like the majority of the cost is in the labor. What do you guys think of the bid?
gobble
Premier Garage here in WI quoted me $5/foot for full rejection flake with clear coat.
Az Scooter
I just paid $2.50 a square foot for airplane hangar epoxy with full chips. It is a little harder then regular epoxy, and less likely to get hot tire lift.
justsam
Penngrove, California
Applying epoxy is measured in hours.
Prepping the floor for the application can be measured in days.
I would not trust any bid that did not detail the prep work and who was responsible for it.
bdamico
As with anything here, read threads on epoxy installs and you'll see what people spend and you didn't give enough details including where you are and what is involved in your install or the present state of your slab
J
JoeGarageHand
Slab is a little over a year old with no grease, etc. 5 stall garage. Basically a clean slate. I am in Lincoln, NE.
Dan Babb
Wow...$5,040 for basic grey epoxy.
How perfect do you want it to be? Might want to buy beer & pizza and have some friends over for a weekend project.
Az Scooter
Our floor prep nvolved diamond grinding and leveling the concrete, and hand grinding all the relief joints. It went far beyond acid washing the concrete.
J
JoeGarageHand
Thanks for the info guys. I am going to attempt this myself. Will be contacting Legacy to buy the necessary products.
