going to look at a lathe
P
partsman
reading pa
i have used aerokroil before that is a great product, but it is real hard to find in my area. the 2 places i knew that sold it have closed down [ both small mom pop stores] since we have 2 huge home depot and one lowes in my area. i talked to a guy at the local speed shop he is going to look into getting me some.
is that amsoil stuff really any good i am starting to see alot of sighns for it but never tried it.
Uncle Buck
Kansas
its a done deal i just called the guy an told i will take it.
going over in the am to pick it up.
the belt sander that is going to be a big help i do alot with sheetmetal and that thing will be perfect.
thanks for your help guys i owe ya.:beer:
if any of you get to the reading pa area let me know an stop in :beer2:
Now that you have sewed er up, more pics please! :)
Charles (in GA)
50 mi south of Atlanta
We could start a whole 'nother thread on Amsoil and if its any good. I am a dealer. I do not push it. I signed up years ago to make it easier for me to purchase my own oil without chasing a dealer down. I am, however, sold on their products. Two products that sell themselves after you have used them once, is gear oils in standard transmissions, makes a ****** that is stiff in cold weather (such as the Pugeot 5 spd in my Jeep Comanche) shift like it was summer time. The other product is the 2 stroke oils. Gas never goes "dead" sitting in the tank of your chainsaw, weedeater, etc, over the winter like normal gas/oil mix. 2 strokes start real easy with it. Not trying to advertise, just making a point, yes the products do work.
Metal Protectant dries to a waxy film and metal will not rust. A drill press column of mine had started to get a film of rust and I cleaned it off good and sprayed it with the Metal Protectant, and it still looks the same, no rust, but since its "dry" it doesn't collect dirt or run off.
Charles
P
partsman
reading pa
see if this works:confused:
Uncle Buck
Kansas
Once you get that thing up and running one of the first things you will need to do is get that old lantern tool post off the compound and replace it with a nice quick change tool post, preferably the wedge type if you can swing it, if not I am sure a piston type would work just fine too. Don't let those guys with deep pockets fool you either, a Phase II quick change will do just fine for a home shop guy, no need to spend all the extra money on an Aloris, Or Dorian I bought mine from Enco and have loved every minute of use I have gotten out of it! Once you get er cleaned up and running you are in for a very good time indeed! Congratulations
W-Cummins
Iowa
here is some good information about your lathe that I copied from the metalworking news group
>> I'm going to look at a Clausing 5914 being sold by a welding shop that
>> is closing at yearend, and I'm looking for a list of issues to be aware
>> of. The seller is an electrician and makes no claim to be a machinist,
>> and isn't able to answer my questions.
>> What I do know: 13" by 40", 208 volts 3 phase, motor HP unknown. Lots
>> of accessories are included, but the seller does not know their names or
>> functions.
>> I also have some more general questions.
>> 1. Does or can the 5914 come with a camlock spindle? (The seller said
>> it was both camlock and threaded; he may have been thinking of the 5C
>> collets showing in the photo.) Or did people adapt threaded spindles
>> somehow? If yes, how well does it work?
>> 2. It is claimed that this 5914 is varispeed. Is this possible? I
>> suppose someone could have modified the machine.
>> 3. How well does the varispeed work, and what are its failure modes?
>> 4. I think that the machine is under power, so I'll be able to listen
>> to bearings. What else should I look for in the headstock?
>> 5. I'll look at the ways for wear. The claim is that condition is
>> good, but who knows what that means.
>> 6. What is the footprint and weight of this machine?
>> 7. What things usually break?
>> 8. What have I missed?
>> Thanks,
>> Joe Gwinn
> AFAIK, the Clausin is a variable speed machine. I have not seen one
> with a camlock setup. Here is a set of pics I goggled up for you to
> look at http://www.pbase.com/clausenm/newtoy
I don't see the original post so will reply to this one.
1) The 5900-series lathes all had L-00 spindles so far as I know.
2) The 5914 had a Reeves drive type variable speed system and was powered
with a 2 HP 3-ph motor. It's easy to power that with a VFD controlled by
the original drum switch.
3) It works well, problems are related to not maintaining Delrin sleeves in
the motor and countershaft pulleys, which can lead to very expensive
repairs, or to air in the hydraulic line, which prevents full speed control.
Replacement sleeves are $30 or so from Clausing and one should plan on
replacing them.
4) The headstock gears are oil lubricated and it is pretty easy to pull the
top for a look see.
5) The ways were flame hardened and generally hold up well. Excessive wear
there could be a cause for concern as it would suggest hard use. Clausing
sells replacement leadscrews and nuts.
6) The 5914 is a 12x36 lathe with a footprint of about 29" x 72" and weighed
around 1,000 lbs.
7) The vari-speed system is the main thing to check. With the machine under
power, check the shaft that protrudes slightly bear the bottom of the left
hand pedestal and look for excessive wbble (~1/8"?). That could indicate
wear on the motor pulley sleeve. With luck, fixing that might be as simple
as replacing the $30 sleeve but there could be damage to the pulley hubs
which is a much more serious situation. Clausing seems to supply most or
all of the parts that routinely need replacement and prices are generally
not too bad IMHO.
8) Accessories like steady, follower, and taper attachment are very hard to
find and bring good prices on the used market so any of those could be a big
plus if you need them or a source of cash if you don't and sell them. The
steady can bring $350 on ebay and the taper attachment $350-600 depending on
condition. The 5914 had a clutch/brake system which some find very useful.
Check the gear train for broken teeth. Spindle nose runout was originally
spec'd at < 0.0003" which is easy to check. Check the oil levels on the
headstock and apron - low or no level might indicate poor maintenance.
Check backlash on the compound and cross feed. The nuts are fairly cheap
and easy to replace ($60 each?). New leadscrews run more like $250. If you
buy, plan on pulling the motor pulley and checking that sleeve for wear.
Most of the bearings on the vari-speed system are standard and cheap to
replace. If the seller doesn't have a manual, Clausing will sell you one
keyed to your S/N for around $25. They need the S/N so get that before
calling and ask for a parts price list. The manual is really pretty good
compared to others I have seen and has lots of maintenance info.
I've been very happy with mine despite having to replace the motor pulley
($700 about 6 years ago). It was fairly easy to disassemble and move down
to the basement. The headstock is pinned to the bed - watch out for that if
you plan on disassembling.
Mike
There is also a yahoo group about Clausing lathes and milling machines you will want to check out.....
William...
P
partsman
reading pa
wow thanks for the info, but i wasnt able to go get the lathe on sat.
i forgot it was hunting season here in pa. all my buddy's were gone. i did go over and pay the guy for it.
i had some old 4x4's sitting around and i took them over and we got it bolted it down to them hopefully they will work like sleigh runners and help in the move.
drmarkr
Tucson
$500.....!!!
I skipped a page or two in this thread, but just in case no one else has said it yet.....
you ****!!!!! :bounce:
MR
P
partsman
reading pa
i cant wait to get this thing home, the shame of it is i am not going to have any time to hook it up and play with it tilll after christmas
drmker i know and can you beleive i am the only call he got about it. i dont even know what i am doing with one yet and i saw it, i always read the little penny pincher books from cover to cover...
