Good ball joint / tie rod end separator?
tym
I'm planning to do the outer tie rod ends on my 2013 Mustang soon (93k miles and I think they're getting a little clunky) and the Ford service manual has warnings about not hammering on them as doing so may damage the steering knuckle. I get that they don't want Zog to beat on it directly with a BFH, but should I worry about using a pickle fork on it?
Or would I be better off with one of those C-clamp style tools?
I haven't done tie rod ends before so appreciate the advice. My last pickle fork use was to get an ancient idler arm off of a '69 Camaro and a clamp-style tool would not have been able to defeat nearly half a century of rust.
bob15
Northeasten, CT
Have access to an air hammer? This kit with an air hammer will make life easy: https://www.lislecorp.com/specialty-tools/pickle-fork-kit
T
tym
Thanks. I do have access to a "medium duty" gear puller. Could that work here or am I just going to snap it in half?
ChrisLS8
Tie rod ends are usually pretty easy to pop out. Half the time I just give a few taps with my drilling hammer and they pop right out
visionguru
Chicago
This style works great for ALL ball joints on a Honda.
Pickle fork can destroy the boots, which destroys the ball joints.
C-clamp and puller style can have fitment issue, you need to have several sizes to choose from.
Super Mech
Bronx,NY
If you are replacing the tie rods a pickle fork is fine. The boots will get ripped but you are replacing them so it doesn’t matter. I have the HF one that ChrisLS8 uses for years. The thing surprising strong. I opened up the fork side of it about an 1/8 on an inch to fit some larger stuff. Every time I crank the daylights out of it and think is going to break it doesn’t and just pops the stud out. Sometimes some mild tapping helps it along. Always put the nut on the stud flush with the end of it before using.
RKA
Just a quick note on using the style visionguru posted...they were designed to handle some force, but don’t crank down too hard on the nut or it will break the tool. You’ll see numerous reviews where people complain about this (they aren’t using it right). Instead, tighten the nut with a ratchet, if the joint doesn’t open up, hit it with a hammer a few times, then tighten the nut a little more, hammer again and eventually the joint will open up and you will have a reusable tool. This is not likely to be an issue with a little tie rod, but a control arm will certainly require this.
T
tym
Thanks, all. I found on the 'bay an SK pitman arm and tie rod puller that measures like it should fit. Failing that, I'll bop the top of the old stud with a drilling hammer after backing off the nut
MattT
I guess that style might all look the same but ain't made the same. Mine is a few years old dealer tool and it doesn't need any babying. Just crank on the sucker until the joint blows apart.
I just picked this up, pricey but very nice. Comes with 3 different forks, a forth oversize one is also available. Much easier to use than the standard style.
That does look nice. The standard ones definitely aren't one size fits all, on fork width or height. Kit price really ain't that bad but another $100 for the extra fork is high.
joe_pinehill1
Northern Virginia
T
tym
Tie rod end remover for 2013 Mustang -
https://www.freedomracing.com/tie-rod-end-remover-211-001-tool-3290-d.html
The Chilton manual never mentions a ball joint separator. It just says separate the lower arm from the steering spindle when removing the front lower arm.
I saw that tool in the service manual but wasn't able to locate one for sale.
I did wind up ordering this, which is about the same price and seems "real": https://www.ebay.com/itm/NEW-SK-PITMAN-ARM-TIE-ROD-PULLER-92506-MADE-IS-USA/362272522138
johninct
Is it then possible to replace just the ripped boot?
seanc_mt
Former professional mechanic here... I have never understood the fascination with using a pickle fork... It ruins the boots. A few wacks with a hammer on the outer part has removed EVERY tie rod I've ever come across probably 10k of them.
Steve_P
Am I the only one that uses an air hammer and pointed chisel? Put the nut on backwards, hit the shank a few seconds in the machining center and it breaks loose. And yes I have pullers and pickle forks but this works in seconds with no damage
setfocus
rust belt
Yep, never had it not work, except maybe once on a bmw. Hit the arm of the knuckle where the tie rod connects, using a hammer with some weight. I'll use a pickle fork on my air hammer for lower ball joints of some designs, if it's being replaced
plinker
Northern Wi
I've used a straight punch with an air hammer before, mainly with pinch bolt style ball joints. Works well if the situation presents itself.
paulsomlo
Northern Colorado
Anyone have any experience with this one? https://www.spcalignment.com/component/spc/?task=part_description&pid=37985
I replaced a wheel bearing on a Civic this past weekend, used the loaner tool from Autozone, but it wouldn't open up far enough, even with the pivot pin at the widest setting - it kept slipping off because I couldn't get the two arms close enough to parallel. The one linked above claims to have four different positions.
visionguru
Chicago
You don't need to get the two arms parallel. Did you hammer the tool all the way in?
It kept slipping off because it's not fully seated. I've used that tool on a Honda Accord without any issues. Civic is supposed to be no larger than Accord.
  • The tool can be inserted from both front and rear side. On an Accord, when the rotor is removed, the front fits better, otherwise, rear fits better. So, if it can't go in well, try the other side.
  • Hammer it in.
  • Leave the nut on to protect the thread. The ball joint stud only needs to be out of the nut by a few mm.
paulsomlo
Northern Colorado
  • Hammer it in.
Nope, didn't hammer it in - I was afraid of ripping the boot. I pushed it in about as far as it would go, maybe it wasn't fully seated, don't know. Tried it on both sides.
visionguru
Chicago
You have to hammer it in to properly seat the tool.
Look at the picture, this tool is unlikely to damage the boot, which is tougher than you expect. There is no room for the boot to be caught in between metal with high force to cause a rip, unlike pickle fork.
The ball joint was replaced @12 years old, and was out of lower control arm 5 times. Still perfect. d611a6bce508871eb1d0981551f0bdc7.jpg
The following South Main Auto video can show you the usefulness of the tool. Start from 10 minute mark.
jgme
vwpieces
Hills, PA
I have also used the air hammer with a flat hammer shaped bit on the side of the spindle.
Most of the time a simple ballpein hammer all that is needed. The method of swing and strike are the important part. Need to ring it like a bell for the vibration to carry and release the taper fit. A dead thug of a blow will do nothing. So the 4lb Thor hammer is not the one to use... 16oz ballpein is my 1st choice to make it ring... It's all in the swing and how you strike it.
And I do have the 2 sizes of the pullers like the HFT one pictured above. Both are of German flavor. But I rarely ever need to resort to using them.
jonesg
northern Maine/
theres even a small flat anvil molded into the knuckle specifically for hitting with a hammer.
Hold tie rod end with one hand, putting it under slight pressure to come out, then hit the knuckle.
DGersic
DeKalb, IL
I have the HF version of this. Works great.
