Good, local wire crimpers
LS6 Tommy
Northern NJ
Can you explain in detail the difference between the Klein 1005 and 1006. I dont undertand non-insulated and insulated.
1005 crimps both insulated and uninsulated terminals. 1006 only crimps uninsulated. You don't use crimpers with a "tooth"'on insulated terminals because it pierces the insulation.
EDIT. I didn't read far enough again. I am redundant...
Tommy
48548
Phoenix
Not my picture, but I have this set as well and it works great and was less than 100$.
rlitman
Long Island
Nice setup. Though I've had little luck with a full-cycle ratcheting crimper on standard insulated or non-insulated barrel connectors. They seem to under-crimp for me , and good connectors (2-piece or brazed seam) tend to do better with a little over-crimping, while cheap connectors like you find at HF just plain ****, no matter what.
The exception to this is on high temperature connectors. They're made from nickel plated steel, and are used a lot in appliances. If I were crimping a bunch of those, I'd probably have a full cycle crimper like this (actually I've got a number of Ideal Crimpmasters, but just don't have this style die set).
BUT, on the open barrel connectors that need to be closed into a pumpkin shaped cross-section, a ratcheting full-cycle style of crimper is the only way to go. Those sort of crimps are VERY sensitive to both over and under crimping, and I don't dare crimp them without the proper tool. Instead, I'll form them into a decent shape and finish with a touch of solder (enough to hold the joint, but not enough to wick far into the wire).
Mike_C
I have a set of Greenlee ratching crimpers, best crimpers I have ever used. I've since tried a few other brands, and so far they have all fell short in comparison. I have a set of dies for insulated, and a set for non insulated connectors.
This picture was when I first got them, I just grabbed the first scrap wire I had to test. I could not pull the connector off the wire, even with tools.
iG_rDjsIutTjUzJWTTcgApJCvAbXjtx4oy3trOZxcjrt99GTfH2HPOyLe0MojB8oMx3Ib6Ux4CiptCTW1Xuv7EOM4iAcWMBjzMuICIOIRYypsr11wbtBTtkEql0bjZo8bEn4eTm93pmzQRztbde0pVfW71EtwwasBhi5bz0Y3fw5fVY9ao65aYnG1Icfr4bmZTL6hdL8vFR5hTdBfPgfeFykMRzvVIr_Ax8qFOJvtfHNfg4e8G7MnW_9lo8DbpTdpAuafdVTHL8JL5NmglojBvpM5hWfiQvrmJkRNQlsPrXx-y-49DeDVLDUCgSA5_6kqqPB8GwWMv_NXx_iOTl92n3zTVcZc8EBA2xp_lUsX_BwBIur55XXuR4-_X5cEH7IEz_Oa6BMmI-E4muiL4RXsz1D6fWwP0Y8IRYjJ2sQzygzJdtixWmL3oWUVv_DolOyoEI3OMB8KqtXJmgmCh3cB-3OW0W5Nomgw9ayMvsH6lGhkmxpGL1C2OVnzQAlS61QRNhNyzPNj9V0mxOrUWI63h5gE1Jb7zNrr1wq2nDEsZPIkWONB0TdF-qOAOfvZCaH7Ciyn50gggM4yLEDzJgYPjZ97_tE3GM=w1420-h799-no
And here it is with both sets of dies.
94zk65xPnPQRu5TEiEeMIOCB_2AjkbRbJVg9yhqStVOnvFId7lDk7oEZHrs0FgL0LNF91REuhi8YPEBmS-UO2yNCGOrswwsN9KPwAJTCwo8uiGUIixLwi1onw6Qmhx4tq69LBLFrEZfPkXDAjQTcDmWRkFqNks5CIq0dU1w_nkLXZVbcvCof0PF-LrlAaRkv21WAEYXrZBi6rzNt4RWy21iVQWRw-Munl-_Iot8mbyadDTS-FA0mBaWgjo0MVbpTq9O6hfFPVJ-VYKXIdHVIXoMLO1wSKgky4BAQG7PtH8WzI4LlSfqc2x3AZQBr_2O4nvgLF4oTAHGLB9NS7XZxksLt5jxuavt9tJR7ikOw8aVazsZQxTbt7hYJNqaXGsp9eKoatTovcfp80zixl0ddn6ySDP5kFHtSbuwFPTqT1SHUjWkARif501xo8K37a2DiuawyDCLgXVDWsNwg9sricZrKFqQzDo_DeN4laFFKUkjgzRFnsQLaqjgy1smCata47iNeFKJK7Em-Kzd97QNS61FR92epRbbTX5SlpKdwWQ8lYD3tdzBYyOsq8Rai5DuGwPfhnj2h5NjayQiPbSzbDMPiVSRIYXE=w1420-h799-no
And a crimp on a non insulated connector
UMEShTpOmeDBXqLlP59k7oTqRBIqcyhmfmp8bv9OIdDghpSmIn-i4t-nsllNbPbfm0ZleNeVb_Cll38x2d67KmfGTdyRPVr1MeGlUSJbm9z2HGwBhGNb5_pjb3s-pv1HL15Kpql3nCFl12gCm0ltaYze_On2OdrYa7tpHJkBzAQiWyJGYCLcxBsYymJehMD3CjYIQq8KG_thY2_XA8IJTTfbxJiS_U7mf-KTBeMEHZtDEYhIVYLaxiu-BUb6uEqR7r6CN_3yrOtCdGcXkPGP_cZOKoc1tOjG3DwgBG8xgxigwYLSDBhVD1moRC4IkYGO5ZYjvlVcBpHrYWh2yjSeDdwCkvKV0NrSAnPLsJ1wuUTjeqqYIa2oaedZCL169K7wq7wYRXtijxa3GO0RbVGRgCUTpfhh9hFDRq-EJQ-fTjVkCOWH3m40_TVYDy5bRMji6HD4O1E5U40pyW8EJGGup8Zq6pYEKP_KTw-S1GDirluostVTfjGGDLbDty3vsRm05UgSye7MKtYpPLjP-PBHf8BqrQAA9_lt6vjHPd6fp25euBn_ied8ic37jfTpx-fIUahAaXR1X0PIQUWhPz67igjaWnwejxc=w1420-h799-no
I have a set of the klines, and other similar designs, but I never felt confident in my crimps when using that style.
https://www.amazon.com/dp/B000WTCWC8/?tag=atomicindus08-20
