Good source for Oetiker clamps?
mikeatrpi
Home
I'm not exactly sure what size(s) I need, but its got to fit over 3/8" transmission cooler hose. OD is about 5/8 or a little larger.
I see multi-packs on Amazon for around $50. Can I do better? Thanks!
plinker
Northern Wi
The clamp sizes are metric, so 5/8 = 16mm. You want the clamp to be as small as possible and still fit the hose when its on the barb.
I bought them off Amazon, dont remember the price off hand of the set, 10packs of one size could be bought as well.
5ktq
keep in mind there are stainless and galvanized ones, different widths etc.
So that you know you're comparing the same ones
I usually just get them from the local industrial hose / hydraulics / etc store, as they'll sell singles.
lis2323
Same here.
BTW I have a proper pinch tool but a CV joint tool works equally well.
plinker
Northern Wi
https://www.amazon.com/gp/product/B017V1AU0K/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B00X6MPQIU/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
I bought these two kits, combined them into another box, and added more of specific sizes that seemed to get used often. They are the single ear CV style clamp in stainless.
I also had picked up the Knipex crimp tool with the side ear, comes in handy at times.
https://www.amazon.com/Knipex-Tools-10-99-i220/dp/B01I3H6UIC/ref=sr_1_1?ie=UTF8&qid=1533780555&sr=8-1&keywords=knipex+ear+crimper
6PTsocket
Oetiker used to get their hand tooling from Knipex. A few years ago they built a plant in Branford, Conn., where they now make their own tools. I have the side crimper. Unless it is a wide clamp, the side crimper also has end crip jaws and will do end crimps equally well. They are a a World wide company but the tools are Made in USA.
rlitman
Long Island
Same here.
b427f05735178a56460c0279ba2ee760.jpg...
Those 2-ear style clamps are not good on rubber hoses. They leave a loose spot that will eventually leak when the rubber loses elasticity.
Go for "stepless" 1-ear Oetiker clamps.
FYI, 1/2" PEX is 5/8" OD. So, if your hose is really 5/8" OD, you can go to the hardware store and pick up the Oetiker clamps made for PEX connections in a 10-pack for far cheaper than you'll pay for a large assortment.
Dingleburry
Great white north in an igloo
I havent really had a problem with them leaking, as another poster said use the smallest that will fit, i go up a size or two so it still compresses the hose but the ears are fully crimped. Or basically touching eachother.
zmotorsports
Northern Utah
I've purchased mine through either my local NAPA or McMaster Carr. Either one has had good quality clamps and reasonably priced.
