Got injured while using an engine stand
poppinjohnnies
Kansas
I was working on Dad's model T engine / transmission last weekend and I made a big boo-boo. The load on the stand swung hard as I was in the process of rotating it and the rotating handle caught the inside of my left thigh as the load swung around. Nothing hit the floor because my thigh took one for the team. the next day I ordered a worm drive hand crank rotating stand (#80059) from Jeg's. I've had several close calls with these cheap stands over the years, but it hurts too bad to get bit, so I'm not letting it happen again.
Ohmthis
Outside of Louisville KY
What kind of stand do you have? I have a couple, I’ve even used 2 at once on a marine 454 with the exhaust manifolds on. That was one heavy *** engine. The swinging of a heavy engine has hurt a bunch of people.
HenryAZ
MEMBER EMERITUS
South Congress AZ
I had one spin on me like that. Thereafter, I always used it under my chain hoist, with the chain supporting the engine as it turned.
MushCreek
Upstate South Carolina
P
poppinjohnnies
Kansas
It’s a garden variety HF 1000 lb stand. We’ve had everything from tractor engines to big block Mopars on it. Had a lot of close calls, but never got thumped until now. My new stand was delivered today, and I got it assembled tonight. Looks decent. I’m going to convert the old one like the one in the video posted on this thread. That’s a great idea.
Sent from my iPad using The Garage Journal mobile app
noid
My philosphy is normally not to save money where injury may be a factor.
Sometimes it takes getting bit to spend a bit more.
Blue924.9
We use an otc revolver at work. [6k rating] with a transmission on the a half decent spin on the handle sends the handle whirling like none other
P
poppinjohnnies
Kansas
William Payne
Wanganui, New Zealand
Yip a geared head engine stand is on my purchase list as well. You just can't put a heavy engine block on those handle turn stands. I am learning that with a Hemi.
toplessHO
central florida
had my JD backhoe motor on the stand and it flipped while trying to rotate.
took out the passenger door of my 68 Firebird.
Lucky for me no personal injury.
